Transponder Registeration??
Old Sep 6, 2006 | 08:52 AM
atl nighthawk oo3's Avatar
Hey do any of you guys know the registeration procedure for a transponder key for a 98 CL?? and programming remote??
I just bought a used CL and it won't stay on. I was driving and all of a sudden, the car would not accellerate. I pull the car over and then the engine shut off. I could start the vechicle, but it would not go anywhere before it shut off again.
I think it might be the ignition recall, but I'm not sure of the vechicle history.
Any help would be greatly appreciated.
Old Sep 6, 2006 | 05:36 PM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
There's a good guide on how to reprogram remote a while back, use the search feature...
As for the transponder problem, i think you should call either Acura's tech service or some honda/acura specialized shops near where you live and get a correct diagnosis for the problem...DON'T go to a dealer, they'll either scare or pressure you into doing something that's not needed so they can charge money.
Try that out and post the solution so others can know what to do if they have the same prob...
Good luck
Old Sep 25, 2006 | 09:01 PM
Colombiano's Avatar
What you have there is an ignition switch recall problem I just got that problem fixed on my 2.3 98 cl sometimes you can wiggle the key to the rght position to keep the car running but that is pretty risky when driving the car can shut off whenever so be careful at intersections be careful period...
Old Oct 4, 2006 | 09:53 PM
Smalls's Avatar
Insert Sarcasm Here
If you can take your key out of the ignition while the car is in gear, you need the recall.
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
izmyttz
Nov 28, 2008 08:03 AM
GrayTLinATL
Jul 6, 2008 12:58 PM
ubnpast
Jun 13, 2007 12:39 PM
Acurich
Feb 1, 2005 07:03 AM
