Transmission problem!!!
Old Apr 16, 2010 | 12:25 AM
TexasTony6777's Avatar
There has been a lot of talk about the transmission in Acura/Honda cars. I have a 1997 2.2CL with an A/T. It's generally ok. Then there is the first gear issue. I can excellerate in first. The second I let off the gas, the car does not slow down to engine/trans drag. It's almost like pushing on the clutch pedal of a M/T. I have the ultimate fix-all.
Install an M/T with ECU and needed parts. Install a street performance clutch and lightened flywheel. Awesome idea. Or Acura could have been smart and put in a transmission filter!!!!. I dunno I could be wrong. Still love my Acura. Got it for free and still haven't put more than 5 grand into it since 2003 when I first got it.
Old Apr 16, 2010 | 09:16 AM
DaInFaMMuS1's Avatar
So you converted your auto to a manual is what you're saying?
Old Apr 16, 2010 | 11:42 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
They have a trans filter, but it's non-serviceable
It's actually the clutch packs and bearings that go bad in the tranny
Old Apr 17, 2010 | 01:02 AM
I didn't do it yet. I'm going too. I've been buying parts here and there, little by little. What ever I can afford and what I actually need. Making sure my axles, suspension, and mounts don't have to change. Haven't got too deep into that yet. If everything goes well I should have everything done in a few months. At the longest, by the end of the year. I hate driving an automatic. I love the feeling I am in control of my car.
Old Apr 17, 2010 | 01:05 AM
That is something I never knew. There is a transfilter? but not servicable! I can't wait to get my m/t in. figured without any horsepower upgrades a street clutch should be fine. then upgrade as I go. I know how to tear down my car piece by piece, just still trying to learn more about the little details that make up the characteristics. Timing belts, parts replacements, noises, I can fix easy.
Old Apr 17, 2010 | 10:30 PM
riefel182's Avatar
does the 1998 3.0cl have a serviceable trans-filter?
Old Apr 18, 2010 | 11:55 AM
APKhaos's Avatar
FWIW the trans on my daughter's 3.0CL died recently. Manged to find a recon replacement for $1500, but that was when the fun really started!
- The vendor delivered the wrong transmission [later model that did not have the speed cable setup required for 1998 cars]
- We send both trans back [my core and the wrong model recon] They promised to recon my original and send it within a few days.
- Trans arrived........WRONG MODEL AGAIN and clearly not my original
- My original finally arrived after being rebuilt. Phew!
- Installed it, and discovered that the brake bands were badly out of adjustment. The trans had all new clutches, bearings, TC etc, but the brake bands needed to be adjusted before it would select gears properly.
Lets just say it was a saga, and maybe an object lesson in what happens if you don't have really good references before you buy a reconned trans!
Old Apr 19, 2010 | 01:42 AM
that's terrible. are they reimbursing you for shipping and troubles?
Old Apr 19, 2010 | 08:07 AM
APKhaos's Avatar
They credited $200 when the first wrong model was delivered. We're still working the case for the rest of the saga.
Old Apr 19, 2010 | 08:27 AM
(Mid-Atlantic)
No, exactly what I said, it has a filter, it's internal, and therefore not serviceable. You would have to drop the trans and remove the gasket to get to it, therefore not serviceable
Old Apr 19, 2010 | 03:01 PM
riefel182's Avatar
but you can take it to a mechanic and have them replace it once your car has seen some years....
Old Apr 26, 2010 | 02:52 AM
XSleepizeX's Avatar
all honda trannies does not have a filter
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
