Tail light out on 3.0cl 1998
My dash light and tail lights went out on my 1998 3.0cl. I checked the fuse box under the hood labeled small lights and the 15amp fuse in their is not blown. Is there something else I should be checking?
Hi, not sure if you fixed your issue yet, saw no responses or updates.
I had an issue in my 97 CL 3.0 once where my radio and cig lighter stopped working. The shop guy said all the fuses were fine, and I watched him testing. He tried everything but couldn't get my radio and cig lighter back on. I finally convinced him to just try changing out the fuse I pointed to (there was 1 fuse that powered both before their individual fuses), and it worked.
Basically, sometimes visual inspections and testers can lie. If the problem is a fuse, you can track down all related fuses using a fusebox diagram.
Don't be afraid to change out a fuse you think is already good.
BoricuaTL
Apr 8, 2016 01:08 PM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
