A/T Transmission Shifting Problem
Old May 13, 2009 | 01:18 PM
soultwista26's Avatar
3rd Gear
Question A/T Transmission Shifting Problem
*1998 Acura CL 3.0*
I Recently changed my Tranny Fluid with a Honda ATF Z1
fluid couple days ago. I notice everytime my car is cold,
it will shift normally. but when im driving over 30 min the car doesnt seem to shift into 2nd,3rd or 4th gear anymore.
its stay on the 1st and i can only go up to 30mph. and i red
some of the forums about this case. and my guess it could be the shift solenoid. But I need more help and more information before i start to fixing the problem. Please Help...
Last edited by soultwista26; May 13, 2009 at 01:19 PM. Reason: Forgot to put what car it is
Old May 13, 2009 | 01:33 PM
Josh99CL's Avatar
You only had problems after a fluid change?
Old May 13, 2009 | 01:37 PM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
My 01 CLS did something similar. It was teh TPS.
Does it "fix" it's self with a restart?
Old May 13, 2009 | 03:31 PM
3rd Gear
Yea. when i had the tranny fluid change. it started the problem idk how and why.
Old May 14, 2009 | 12:59 AM
01redcltype-s's Avatar
im sorry but my 2001 cl s is doing the exact same thing when i got my tranny serviced it ran great for two days then when it warmed up it would not shift and then i would shut it off then turn it on and the problem would go away for a few miles then start all over again and now it does not go into reverse or drive car does not move please help do i need a new tranny or can i salvage this one tranny has only 57k on it
Old May 16, 2009 | 12:45 PM
WineRed2.2CL's Avatar
Old School Ridin Clean
man that sucks
Old May 16, 2009 | 01:00 PM
Anhedonia's Avatar
it sounds like the tps to me.. did you change the fluid yourself? or get it done by a shop?
Old May 16, 2009 | 01:48 PM
beachexotic03's Avatar
I'm no trany expert. But sounds to me that they didn't ajust the servo when they did trany fluid change. I have had some same problems in diff types of vehicles. When you change fluid you always clean the servo. See what happens is that new fluid comes into the TQ converter then rerouted through the trans then passes by the servo. If the fluid is too thin or (clean) the vaccum that is draws throught the trans isn't enough do to build up old sludge from old fluid. thus it will stick if new fluid is pumped through it and it was never cleaned it will stick than not stick? Fallow me? Image a straw if you stick it in milk shake and suck it's fine but us the same straw stright out of a milk shake and put it into a glass of water you suck harder and get less water?? so same thing when changing trans fluid you have to clean the servo before anything good happens same as a straw.
Old Jun 2, 2009 | 01:24 PM
killinit8459's Avatar
7th Gear
usually its the tranny that is going when there warming up than not shifting recently happened to me untill i had to replace tranny car wouldnt move aafter it got warmed up or would slip out of gear
mada51589
Jan 9, 2025 04:40 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
