Suspension Noise
Old Aug 25, 2006 | 12:41 PM
Motion's Avatar
Suspension Noise
I have this really wierd noise coming from the front passenger side suspension. Its like a creeking noise that I really notice when making left hand turns and when I straighten the steering wheel back out. Almost sounds like something may be slightly loose or bent. I plan on taking a good look this weekend but wanted to post to see if anyone had any ideas what it could be? Thanks in advance!
Old Aug 25, 2006 | 04:01 PM
TexasHonda's Avatar
Anti-sway bar rubber bushings (bar/body) are likely. The sway bar twists in the bushings when you turn or particularly when you go over a bump on one front wheel. The brackets can be loosened, bushings removed and lubed, and remounted. I believe it's a split bushing that will pull off when bracket is removed.
good luck
Old Aug 26, 2006 | 11:12 PM
Motion's Avatar
Thanks, I'll have to check that out.
Old Aug 29, 2006 | 08:44 PM
celynka's Avatar
Sundance Gold in
its probably half shaft cv joint boot being cracked. when u hear that sound cv joint is already gone.
Old Aug 30, 2006 | 07:01 AM
Motion's Avatar
Wouldn't that be something that would be caught during inspection??? I'm gonna take a look at the sway bar bushings this weekend and see what I can find. If its not them I guess I'll have the CV joints checked. Thanks.
Old Sep 1, 2006 | 09:40 AM
Motion's Avatar
Checked it out last night, definitely not the swaybar bushings. Took a closer look, appears to be coming from the joint right behind where the brake rotor is and where everything meets.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
