Suspension Noise
Suspension Noise
I have this really wierd noise coming from the front passenger side suspension. Its like a creeking noise that I really notice when making left hand turns and when I straighten the steering wheel back out. Almost sounds like something may be slightly loose or bent. I plan on taking a good look this weekend but wanted to post to see if anyone had any ideas what it could be? Thanks in advance!
Anti-sway bar rubber bushings (bar/body) are likely. The sway bar twists in the bushings when you turn or particularly when you go over a bump on one front wheel. The brackets can be loosened, bushings removed and lubed, and remounted. I believe it's a split bushing that will pull off when bracket is removed.
good luck
good luck
Sundance Gold in
Originally Posted by celynka
its probably half shaft cv joint boot being cracked. when u hear that sound cv joint is already gone.
Checked it out last night, definitely not the swaybar bushings. Took a closer look, appears to be coming from the joint right behind where the brake rotor is and where everything meets.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
