stupid car
Old Apr 14, 2010 | 03:15 PM
f22vtec's Avatar
stupid car
ok, you know when you insert the screw in the turn signal through that little plastic piece thats a part of the bumper? for some reason that piece broke so now my turn signal can't stay in place and idk what to do a zip tie cant do it the way everything is placed cant get in the area i need it to to hold it in place.
again its the little vertical rectangular piece that is the same color as the car not the black piece with the circle cut out in it. PLZ HELP
Old Apr 15, 2010 | 12:02 AM
TexasTony6777's Avatar
Hello, here is a simple hint.
First: remove both front turn signal assemblies. Second: get a 12mm socket on a 3/8 drive with a 10 or 8" extension. take out 4X bolts (2 per side) holding the bumper brackets on. Make sure to unscrew and remove push pins throughout splash gaurd, wheel liners, and the two that screw into each fender. whole bumper with air dam should come off in one piece. Put a blanket down first to reduce scratches to paint. the you will have allllll the access you need to modify the bumper to hold the turn signal assy in place. Go to auto parts store and buy the smallest fiberglass kit available. then do what is needed to create a spot to screw into. it's easier than it looks.
Old Apr 15, 2010 | 12:04 AM
I have pictures of my whole front end tore down. Pretty scarry looking to the unknowing eye.
Old Apr 16, 2010 | 07:18 PM
f22vtec's Avatar
yea man its crazy lol
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
