Steering/Brakes?
Old Mar 27, 2007 | 06:36 PM
Gorm's Avatar
Unhappy Steering/Brakes?
Hello everyone.
Have the following issue...
When braking, at any speed from 50kmh and up, get rather hard vibrations on the steering wheel.
The car stops, but what happens isnt healty. Car doesnt pull to the right, or to the left... Started probably about 1 year ago... Tried different things, sometimes it would go away for a month or so, but then would come back.
What I've done:
*New tire rod end (whatever is the right spelling - im sure you guys know what im talking about)
*New disks and break pads
*Alignment was done, but will do it again bc brake job was done just recently.
*New tires on front.
Buddy of mine says that the next thing he would look at is a power steering rack.
Would it be the cause? Anything else that i can check?
Also, few month ago my SRS light came on... when i was parked and idling in the middle of the parking lot. WTH? where to look for this one?
Any ideas at all? Im just tired of all those annoing things on otherwise very nice car...
Old Mar 28, 2007 | 08:44 AM
saiko_cl_duck's Avatar
are your tires good? bad tires will cause that, or even if they're not balanced properly.
Go to the DIY section, I did a write up on how to reset the SRS light.
Old Mar 28, 2007 | 11:18 AM
Gorm's Avatar
Saiko
As i said, brand new tires on front wheels. Balanced too.
I dont think the rear tires matters (right?).
And i will try the SRS reset over the weekend, post here the results...
also, forgot to add. brand new upper control arms (those triangular shaped things with upper ball joint).
Old Mar 28, 2007 | 11:24 AM
pardon me, my brain took a short vacation.
Old Apr 26, 2007 | 11:03 AM
stacman's Avatar
9th Gear
How are your brake rotors doing?
Old Apr 27, 2007 | 10:34 AM
Gorm's Avatar
Hey there.
As I said (maybe because of my wording - i wrote "disks" when i meant "rotors"), rotors have been replaced. Some time ago I also blamed rotors, had them checked, and they were warped. I had them machined - didn't make any difference whatsoever. Few month after that i decided to replace them anyway. So, rotors are new - couple of month old.
Follow-up question on SRS reset. I found the connector, but can't pull it out. Any suggestions, other then disconnecting fuse box, and taking a peek at the connector in less restrictive conditions?
Old Apr 27, 2007 | 08:41 PM
you don't have to disconnect the fuse box man, it's a dummy plug on the inside of the dash, right above your left foot.
https://acurazine.com/forums/showthread.php?t=187314
Old Apr 28, 2007 | 10:55 AM
Gorm's Avatar
I found the plug. I just cant pull it out. I dont know if there are clips on 3 sides, or if the connector fused with the plug, or what... i had a buddy of mine who used to work in car audio/video install shop to try it - he couldnt get it out either.
Old Apr 28, 2007 | 11:16 AM
Gorm's Avatar
ok. checked your link again, see that instead of disconnecting it on the fuse box, where i was trying to do, it shows that you disconnected it somewhere in the middle... ill try it later today
Old Apr 28, 2007 | 03:22 PM
Gorm's Avatar
ok, the guide talkes about disconnecting yellow cable from the fuse box.
Your last post suggests disconnecting it somewhere in the middle.
now, those seem to be 2 different connectors.
is it safe to mess around?
Old Apr 28, 2007 | 03:46 PM
no.
the connector IS NOT ON THE FUSE BOX.
Get on your back, under the dash, and look toward where the front of the dash is. There is a yellow connector sitting inside a dummy plug. The dummy plug DOES NOT connect to anything, it's just there to hold the connector.
It is on the lower left corner, follow the big box to where the little box is. It's right there.
Old Apr 29, 2007 | 10:54 AM
Gorm's Avatar
Yeah. Did that, figured out already.
Anyway, tried the procedure 5 times - doesnt work. SOmething else must be wrong.
Thanks.
Old Apr 29, 2007 | 09:41 PM
sounds like you need to bring it somewhere and have it looked at.
bletour
Aug 15, 2013 08:47 AM
