SRS light help
Old 03-01-2011, 05:12 PM
97greenclbro's Avatar
SRS light help
i removed my steering wheel to replace the worn out one on there and i thought i waited the 3 min before taking it apart. i continued on with taking it off, but when i pulled the wheel off, i spun the srs cable reel around and im not sure where the original location was. i got it lined up best as i could, and put the wheel back on. when i started up my car the next time, my srs light was on. was this cause i didnt wait long enough to take the wheel off? or did i mess up the srs cable reel?
but most importantly, does will the airbag still deploy with the srs light on and also how do i go about turning it off?
i have no manual for my car so any help would be appreciated...
thanks
Old 04-18-2011, 07:38 PM
6th Gear
gearhead89's Avatar
i would suggest disconnecting the negative terminal of the battery for about 20 min to reset the pcm the light should go off and stay off then
Old 08-08-2011, 10:24 AM
MMkay.
Project_CLean's Avatar
OK;SO:
air bags will not deploy,the srs light indicates a malfunction in the system therefore will not permit the airbags to deploy.
as for resetting you can't just unplug the battery;srs system isn't wired like that. besides taking it to honda or a shop with a Snap On reader or something you can jump the SRS service connector. years ago i did it on my accord which should technically be the same thing. just cant explain to you exactly how.. theres gotta be an article somewhere online. you would just need a paper clip or a piece of wire
Old 08-08-2011, 05:49 PM
saiko_cl_duck's Avatar
This is why we have the noob guide, it's covered in there.
https://acurazine.com/forums/1g-cl-1997-1999-56/%2A%2A%2A-1st-gen-noob-guide%2A%2A%2A-494068/
Old 08-09-2011, 11:53 PM
P0401's Avatar
the srs plug is yellow and near the fuse panel, just jump it off. You can reset it by doing the jump/release pattern (not sure of the pattern but if you look it up you will find it) if there is a problem even when you reset it the light will com back on as soon as you start the car next time
Old 08-10-2011, 12:50 AM
Miiike's Avatar
If you want to get the code go under your glovebox and find the blue connector under there and jump the 2 things in it with a paperclip while the car is off then turn the key to on and your SRS light will flash you a code. The codes are shown here: https://acurazine.com/forums/1g-cl-1997-1999-56/srs-troubleshooting-noob-guide-494077/
mada51589
05-03-2022 08:54 PM
12-07-2020 05:39 PM
mugen_kid
11-13-2015 10:38 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: SRS light help
