Some cruise control issues
Old Aug 17, 2014 | 02:49 AM
claccurate93's Avatar
Cool Some cruise control issues
So to start off the cruise control has not worked since I purchased the car
Alas. You're my only hope left I've asked so called "honda" experts yadda yadda.
My issue! : I've check fuses to both the cruise control and horn they're fine. The left hand horn button is not functional, but the right one is?..
Also I read somewhere a clock spring might be the culprit but I have no troubles from the turn signals the other horn button. No problems with an srs light OR switches under the dash I.e clutch and break (5speed)
Side note no power or light to the dash for cruise control or the switch. Have ran a multi meter to them no power to the cruise control switch.
Could it be some things just unplugged if so where? This car is in excellent shape I can just tell some things were just left undone.
I had some issues with the air conditioning and the clutch petal it's self when first buying the car.
Thanks!
Daniel
Old Sep 11, 2014 | 05:36 PM
AnErin's Avatar
6th Gear
I imagine you got this figured out by now but -
One of the probs with the CL is there is this plastic throttle cable holder which houses the cruise control cable. Check there to make sure yours is not broke.
Old Sep 18, 2014 | 08:21 AM
dustin2493's Avatar
It might sound crazy but ive heard this from several other people and its working on my 97 3.0 when it does occasionally happen..i wiggle my steering wheel a little back and forth and then SET cruise again and it should come back on.
Old Sep 24, 2014 | 01:11 AM
Showmeyourtints's Avatar
Yep. I have no cruise control. I've never looked into why tho. I don't care as much about cc then I do cold ac. Or the engine sputtering. Etc etc.
Old Jul 25, 2018 | 02:32 PM
jquandtx's Avatar
My cruise control worked then it worked gain upon a rare occasion but usually not. I haven't solved that problem, yet. Could be the plastic cable as mentioned in one of the above comments? above
Old Jul 25, 2018 | 06:09 PM
frankjnjr's Avatar
FWIW: Just to clarify, the throttle cable in question, is steel. The wheel type piece, the throttle cable attaches to, is plastic. It's the plastic wheel, which breaks.
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
