shifting problems
Old Jan 3, 2006 | 02:20 PM
99_CL_girl's Avatar
Im so CrUnK
shifting problems
I been noticing that when I shift to 1st & 2nd gear my shifter feels like its getting stuck. It hard to put it in theose gears, but the rest are fine. I just replaced the clutch not even a year ago. Any ideas on what it could be??
and i already tried searching the web for answers & came up short handed.
Old Jan 3, 2006 | 04:06 PM
ayougo's Avatar
B A N N E D
why dont i come over and ill help you shift the stick for you. I have one that is silky smooth We can work out the sticky later on
jk
But if its sticking, it may be your sincros. If there off, its often hard to get into gear. I would also recommend lubricating the moving parts in the system as well. ALthough changing your tranny oil may not do much, its good to do that as well.
Old Jan 4, 2006 | 02:04 AM
saiko_cl_duck's Avatar
yeah, it could be synchros, and definitly lube everything up
Old Jan 4, 2006 | 12:19 PM
wilp99's Avatar
no... the syncro's would be a grinding problem.. the forks are what align the gears.. you may need a new clutch again.. if you used a cheap clutch. could also be a weak slave cylinder.. theyre only 30$ for a new one, and you can install it and bleed it down in like 30 min. if the slave cyl is worn it wont disengage the clutch all the way, and make it feel like a slipping clutch.. but i do agree , maybee change the gear oil, to be alittle thicker. 80w90.. is perfect, and will lube the inside pretty good.
Old Jan 4, 2006 | 02:33 PM
ayougo's Avatar
B A N N E D
word, if your pedal pressure is shity its probley your slave. I had to replace mine not to long ago and it helped out a good bit. make sure nothings bent under the console as well. ( rods ) i had this issue when i got the car. Be sure to make sure,..nothings interfering with the shifter itself too.
Old Jan 4, 2006 | 02:38 PM
99_CL_girl's Avatar
Im so CrUnK
I bought the stock clutch kit that acura suggested. Someone said to take the boot off & see that everything is screwed in tight. I wouldnt say it feels like its slipping though. Just feels like the shifter is getting caught up on something.
But by gear oil do you mean tranmission fluid? The acura mechanics told me that the 99 2.3 cl takes brake fluid.
Old Jan 4, 2006 | 03:41 PM
99_CL_girl's Avatar
Im so CrUnK
my pedal feels fine. But I will check the other shit.
Old Jan 4, 2006 | 09:35 PM
rajin_2.3cl's Avatar
trini to de bone !
hmm i've noticed mine feels like that too
when i just pull down the shifter from 1st to 2nd, when it gets halfway it feels like it stops and i gotta kinda move it around a bit and throw it down into 2nd
Old Jan 4, 2006 | 11:10 PM
agranado's Avatar
how handsome I am
check all the fluids? Clutch and shifting can feel weird if fluids are low maybe...
Old Jan 17, 2006 | 10:09 PM
jdalton's Avatar
i just experienced this today as well. i had to force all the gears in and my clutch pedal keeps sticking as well. could this be the slave cylinder as well? i sure hope so bc i really dont want to replace a clutch- $$$$ that i dont have. :shakehead
Old Feb 4, 2006 | 10:23 PM
asianspec's Avatar
Yea, im havin a similar problem and sometimes i have to shove the sonuvabitch in there! I hate it when im at the light and im in neutral and i can't get it into first when the light is green.
Old Feb 5, 2006 | 03:16 AM
Bigpimpin18's Avatar
Soon to be H22 turbo!
dude I had this same problem, it was my clutch slave cylinder.
Old Feb 5, 2006 | 11:13 AM
teh CL's Avatar
when i shift my clutch only comes up about half way and it feels mushy as hell
is this my slave cyclinder too
Old Feb 20, 2006 | 11:48 AM
JORTS's Avatar
i just started to notice this same problem....and i just got a new clutch put on about 3-4 months ago
if its the clutch slave cylinder like some of you said, is that a big fix/expensive...
Old Feb 20, 2006 | 12:56 PM
starboy2nv's Avatar
First EVER K24 Turbo CL
had the same prob with the old cL... changed the master and slave cylinder and the car drove like brand new...
Old Mar 13, 2006 | 07:53 PM
asianspec's Avatar
how much did that run you?
Old Mar 17, 2006 | 05:20 PM
trini to de bone !
so I finally got around to changing my clutch master and flushing the fluid....shit that stuff was dirty as hell LOL
car shifted noticably smoother, better clutch feel
next mission tomorrow is to change my manual tranny fluid
previous owner did nothing put change oil, put gas in it and drove so time to get caught up on all the maintenence
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
jfman55
Sep 5, 2015 02:55 PM
