shifting an automatic
01 Type-S, Sexy Silver
Yes, its bad. And pointless. The car will shift at redline at wide open throttle if you leave it in D4, which is what you're trying to do anyways... Believe the right term for what you're doing is "gate shifting".
i dont think its "bad" because it just tells the computer to shift instead of it doing it on its own. It just puts you in control, as if you were in snow and wanted to keep it a gear lower. No gain for normal driving use, probably just use more gas. If you see it done, slap a bitch
6spd FTW
Well... from a past experience I would say it's terrible. I used to make my accord chirp gears by doing that. Needless to say, the trans no longer works. I wouldn't dare try that on a 3.0 glass transmission.
'99 2.3 CL
shifting the transmission manually will not "mess it up."
But if you're shifting manually while engaging in high RPM, heavy throttle-spirited driving; the added stress, heat and torque will shorten its life.
It's most important to consistently change the ATF about every 30-40K and always use Honda/Acura ATF-Z1 fluid.
Using the different gears is completely OK. Using D3 when driving in the city or driving aggressively is completely OK. Using 2 when driving in heavy snow or ice is fine. Using 1 when off-roading is OK.
SidhuSaaB
05-30-2020 12:40 AM
guyvelella
09-30-2015 11:02 PM
Joe Avesyan
09-29-2015 03:57 PM
