Security alarm needs HELP!
Old Apr 13, 2008 | 03:06 PM
TMO's Avatar
TMO
For the last 10 mounths, the alarm does not arm at all. I got it checked by the dealer and all sensors seem to be fine.
The alarm light does not flash after I locked the car, neither does the chirping work even after trying the lock and trunk trick. If I hold the Panic, the alarm goes off normally.
I really want my chirping to work and mainly my alarm so at least if someone is trying to steal it then there is some security.
Maybe it could be the shock sensor? but where is it? or maybe the hood latch sensor? but do I fix it?
Please!! does anybody have any help they can give me?
Old Apr 14, 2008 | 04:49 PM
saiko_cl_duck's Avatar
97 or 98-99?
Plus, search for the alarm chirping, it's been covered before.
https://acurazine.com/forums/showthr...ighlight=alarm
It sounds like your alarm is working fine, but do the lights flash on and off when unlocking? If the sensors are fine, it could be your bulb inside the indicator unit went out. There's an easy way to test it. Loosen ( you don't really have to remove ) your door panel. Unplug the indicating unit and gently pry it out. Hook up battery power to the No.2 pin on the connector and ground the No.1 pin ( To figure out which is which, hold the connector so the small tab or locking part is at the top. Left is No.1, right is No.2 ). If you do not get a indicating light, it's a bad unit, replace it.
Try that first before chasing down sensors and screwing with the control unit.
Old Apr 15, 2008 | 06:14 PM
TMO's Avatar
TMO
its a 98 2.3, and I did lots of seaching but no luck. The lights dont flash when I lock or unlock the car either. But I dont really get your instructions?!? does the alarm not work cuz of the light?
Old Apr 16, 2008 | 11:40 AM
Try getting it to beep first, see if that works.
If not, try taking out the indicator (sits on top of your drivers side door) and test it. Also sounds like a possible relay is blown. Try making it beep, then get back to us.
Old Apr 16, 2008 | 03:47 PM
TMO's Avatar
TMO
doesn't beep at all. doesn't flash.
where can I find and Fix the relay?
ill check the light once I get back to my home town.
Old Apr 16, 2008 | 10:24 PM
There's a lot of fuses, and the only way to really troubleshoot is to take out the passenger's front seat and do a input test with a multimeter.
Have you checked all your fuses under the dash and under the hood?
Old Apr 17, 2008 | 09:06 PM
TMO's Avatar
TMO
ok, how do I do this input test? I have no idea how everything works.
and just add, the chirp randomly worked onced today?!? only on the unlock. then I tried to lock it and try again and no luck.
Old Apr 17, 2008 | 10:30 PM
I can shoot you an email with instructions, but it's gonna be a few hours worth of work at best.
You have to take out your passenger seat and test pins on the connectors for the control unit.
Again, have you checked all the fuses for the car?
Old Apr 18, 2008 | 09:09 PM
TMO's Avatar
TMO
ok, thanks for the help soo far.
Now I checked all the fuses and all of them are fine.
So just for fun I checked the control unit and unpluged both connections, and of course I couldnt use my remote. now I plugged in only one, the smaller one to the left (or the one closer to the rear/trunk of the car) and the chirp works. But with the front connector not pluged in what will this do? I should run a test with the pins, cuz that might be what's causing the problem.
Old Apr 18, 2008 | 10:04 PM
monsieur le technologue's Avatar
The unpluged connection contain the hood switch and I confident that it could be your problem , the reason why you don't see your led and heard the beep is that your security system don't come on because he think that a door , trunk or hood still open and wait that you close it before starting. Actually your system work because your system is blind ( a part of the actuator used by the security system) is not plugged in your case all the input for lock and unlock and your hood latch. So you should replug your security system and unpluged the switch located under the hood latch (the only wire that go to the latch ) . If you still have problem pm me I had many problem solve in my car with that security system and i may help you
Old Apr 19, 2008 | 02:17 PM
well, give what he said a shot, disconnect your hood sensor. If you want to do the input test, let me know.
Old Apr 20, 2008 | 11:57 AM
TMO's Avatar
TMO
so I've tried pluging in back the control unit connections and unpluging the hood sensor, but no luck. still not flasing nor beeping and not activating.
Saiko I will try the input test. check you PM.
Old Apr 20, 2008 | 03:40 PM
Post
As promessed
Cut the one in front with the blue connector
Old Apr 20, 2008 | 05:38 PM
email sent man. Good luck.
Jul 16, 2017 07:33 AM
eastcoastguy
Oct 29, 2015 03:00 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
