Scanner readings
Scanner readings
Hi.
I just bought a scanner (MaxiDiag PRO MD801) just to have.I took some live readings and don't really know the meanings of the results.It's a 97 Acura CL 3.0L,260,000 KM'S.This is a sample:
------------57------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 51.0
ECT(°C) 93
SHRTFT1(%) -9.4
LONGFT1(%) -6.3
MAP(kPa) 47
RPM(rpm) 1671
VSS(km/h) 43
SPARKADV(°) 35.5
IAT(°C) 62
TP(%) 13.7
O2SLOC B1S12--B2S----
O2B1S1(V) 0.175
SHRTFTB1S1(%) -10.9
O2B1S2(V) 0.760
SHRTFTB1S2(%) -15.6
OBDSUP OBDII
------------58------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 29.4
ECT(°C) 93
SHRTFT1(%) -7.0
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1046
VSS(km/h) 41
SPARKADV(°) 18.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.855
SHRTFTB1S1(%) -9.4
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
------------59------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 28.6
ECT(°C) 93
SHRTFT1(%) -3.9
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1008
VSS(km/h) 39
SPARKADV(°) 14.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.820
SHRTFTB1S1(%) -4.7
O2B1S2(V) 0.720
SHRTFTB1S2(%) -5.5
OBDSUP OBDII
------------60------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 30.2
ECT(°C) 93
SHRTFT1(%) -6.3
LONGFT1(%) -6.3
MAP(kPa) 31
RPM(rpm) 877
VSS(km/h) 30
SPARKADV(°) 10.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.175
SHRTFTB1S1(%) -7.0
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
------------61------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 32.9
ECT(°C) 95
SHRTFT1(%) -5.5
LONGFT1(%) -6.3
MAP(kPa) 34
RPM(rpm) 811
VSS(km/h) 9
SPARKADV(°) 6.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.055
SHRTFTB1S1(%) -3.9
O2B1S2(V) 0.055
SHRTFTB1S2(%) -3.9
OBDSUP OBDII
Are these good numbers?Is there somewhere that I could find the meaning of the categories?
Thanks.
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 51.0
ECT(°C) 93
SHRTFT1(%) -9.4
LONGFT1(%) -6.3
MAP(kPa) 47
RPM(rpm) 1671
VSS(km/h) 43
SPARKADV(°) 35.5
IAT(°C) 62
TP(%) 13.7
O2B1S1(V) 0.175
SHRTFTB1S1(%) -10.9
O2B1S2(V) 0.760
SHRTFTB1S2(%) -15.6
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 29.4
ECT(°C) 93
SHRTFT1(%) -7.0
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1046
VSS(km/h) 41
SPARKADV(°) 18.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.855
SHRTFTB1S1(%) -9.4
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 28.6
ECT(°C) 93
SHRTFT1(%) -3.9
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1008
VSS(km/h) 39
SPARKADV(°) 14.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.820
SHRTFTB1S1(%) -4.7
O2B1S2(V) 0.720
SHRTFTB1S2(%) -5.5
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 30.2
ECT(°C) 93
SHRTFT1(%) -6.3
LONGFT1(%) -6.3
MAP(kPa) 31
RPM(rpm) 877
VSS(km/h) 30
SPARKADV(°) 10.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.175
SHRTFTB1S1(%) -7.0
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 32.9
ECT(°C) 95
SHRTFT1(%) -5.5
LONGFT1(%) -6.3
MAP(kPa) 34
RPM(rpm) 811
VSS(km/h) 9
SPARKADV(°) 6.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.055
SHRTFTB1S1(%) -3.9
O2B1S2(V) 0.055
SHRTFTB1S2(%) -3.9
OBDSUP OBDII
Thanks.
Hi.
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 51.0
ECT(°C) 93
SHRTFT1(%) -9.4
LONGFT1(%) -6.3
MAP(kPa) 47
RPM(rpm) 1671
VSS(km/h) 43
SPARKADV(°) 35.5
IAT(°C) 62
TP(%) 13.7
O2B1S1(V) 0.175
SHRTFTB1S1(%) -10.9
O2B1S2(V) 0.760
SHRTFTB1S2(%) -15.6
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 29.4
ECT(°C) 93
SHRTFT1(%) -7.0
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1046
VSS(km/h) 41
SPARKADV(°) 18.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.855
SHRTFTB1S1(%) -9.4
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 28.6
ECT(°C) 93
SHRTFT1(%) -3.9
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1008
VSS(km/h) 39
SPARKADV(°) 14.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.820
SHRTFTB1S1(%) -4.7
O2B1S2(V) 0.720
SHRTFTB1S2(%) -5.5
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 30.2
ECT(°C) 93
SHRTFT1(%) -6.3
LONGFT1(%) -6.3
MAP(kPa) 31
RPM(rpm) 877
VSS(km/h) 30
SPARKADV(°) 10.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.175
SHRTFTB1S1(%) -7.0
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 32.9
ECT(°C) 95
SHRTFT1(%) -5.5
LONGFT1(%) -6.3
MAP(kPa) 34
RPM(rpm) 811
VSS(km/h) 9
SPARKADV(°) 6.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.055
SHRTFTB1S1(%) -3.9
O2B1S2(V) 0.055
SHRTFTB1S2(%) -3.9
OBDSUP OBDII
Thanks.
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 51.0
ECT(°C) 93
SHRTFT1(%) -9.4
LONGFT1(%) -6.3
MAP(kPa) 47
RPM(rpm) 1671
VSS(km/h) 43
SPARKADV(°) 35.5
IAT(°C) 62
TP(%) 13.7
O2B1S1(V) 0.175
SHRTFTB1S1(%) -10.9
O2B1S2(V) 0.760
SHRTFTB1S2(%) -15.6
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 29.4
ECT(°C) 93
SHRTFT1(%) -7.0
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1046
VSS(km/h) 41
SPARKADV(°) 18.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.855
SHRTFTB1S1(%) -9.4
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 28.6
ECT(°C) 93
SHRTFT1(%) -3.9
LONGFT1(%) -6.3
MAP(kPa) 29
RPM(rpm) 1008
VSS(km/h) 39
SPARKADV(°) 14.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.820
SHRTFTB1S1(%) -4.7
O2B1S2(V) 0.720
SHRTFTB1S2(%) -5.5
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 30.2
ECT(°C) 93
SHRTFT1(%) -6.3
LONGFT1(%) -6.3
MAP(kPa) 31
RPM(rpm) 877
VSS(km/h) 30
SPARKADV(°) 10.0
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.175
SHRTFTB1S1(%) -7.0
O2B1S2(V) 0.720
SHRTFTB1S2(%) -6.3
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT(%) 32.9
ECT(°C) 95
SHRTFT1(%) -5.5
LONGFT1(%) -6.3
MAP(kPa) 34
RPM(rpm) 811
VSS(km/h) 9
SPARKADV(°) 6.5
IAT(°C) 62
TP(%) 9.8
O2B1S1(V) 0.055
SHRTFTB1S1(%) -3.9
O2B1S2(V) 0.055
SHRTFTB1S2(%) -3.9
OBDSUP OBDII
Thanks.
it looks pretty strait forward although i dont know a couple.
(1st) i dont know but looks like a computer system startup check.
(2nd) is the fuel system check (probably for the prime and start)
(3rd) is fuel system check (probably for the operation)
(4th) is the load on the fuel system.(fuel pump??)
(5th) is the engine coolant temp (looks good and steady)
(6th & 7th) are for the idle contorll (yours look ok, i think you want to stay in the negatives)
(8th) is your map sensor
(9th) is your standing rmp's at scan. (looks ok.)
(10th) ????
(11th) is the spark advance or timming (this can give problems if out, yours might be out but i cant tell)
(12th) is the temp of air as it enters the engine
(13th) is the throtle possition sensor
(14th)
(15th, 16th, 17th, 18th, & 19th) are for the o2 sensors
(20th) is the sensor system the car runs.
give or take that is what i can give you , good readings from a quick look.
zippy33 (05-30-2012)
MrHeeltoe
20
02-23-2023 02:54 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
