RPM idling up and down
Old Oct 25, 2011 | 11:07 AM
prioris's Avatar
I have 1999 Acura 3.0 CL.
Car is running rich. The rpm idling up and down after starting.
I have replaced the throttle body
Do I need to have car computer reprogrammed ?
Old Oct 25, 2011 | 11:53 AM
Ayu688's Avatar
Could be your Idle Air Control Valve.
Old Oct 25, 2011 | 12:04 PM
prioris's Avatar
If I replace the throttle body, does the car computer need to be reprogrammed ?
Do you know where to find a label diagram of the throttle body and all the sensor locations
There are 3 sensors
one on top
one on left
one at the bottom
which is which
Old Oct 25, 2011 | 01:48 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Did you reset the ECU?
Pull the positive battery terminal for about 5 mins, that will reset your car
Old Oct 25, 2011 | 02:45 PM
prioris's Avatar
power removed during replacing battery so I assume car reset
had to replace the battery yesterday
Old Oct 25, 2011 | 04:02 PM
SupraManAG's Avatar
One custom CL
IACV with tb cleaner
Old Oct 25, 2011 | 04:20 PM
prioris's Avatar
would like to know because i find it hard to believe ... need verification
If one did replace the throttle body, does the car computer need to be reprogrammed ?
Old Oct 25, 2011 | 05:17 PM
SupraManAG's Avatar
One custom CL
If you feel like burning your money in a new $300 throttle body then do so. Remove your idle air control valve and clean with throttle body cleaner. It will take you appx 20 minutes. Full results in 10 hours or so...
Old Oct 25, 2011 | 06:10 PM
prioris's Avatar
someone got a used throttle body and was told they needed their car computer to be reprogrammed in order for the throttle body to work correctly
the original and used part had the same symptoms
maybe original is ok and just needed to be cleaned
can someone tell me what the three connections to throttle body are
are there any diagrams one can give me pointer to
Old Oct 25, 2011 | 06:46 PM
SupraManAG's Avatar
One custom CL
For what. I believe its a 12v, signal voltage to ecu and a ground. You still arnt listening. You have a dirty iacv. In the process u can clean your tb as well
Old Oct 25, 2011 | 08:39 PM
DaInFaMMuS1's Avatar
Throttle body is not a control module, so why would the car need to be programmed in order to use a new one? Someone was trying to make a quick $$$....
Listen to this advice. clean our ur iacv and TB, reset the ecu via pulling the batter terminal for 5-10 mins and see what happens after.
Old Oct 25, 2011 | 09:23 PM
prioris's Avatar
Will take IACV off throttle body and clean it up
Hopefully that solves problem
p.s.
the other question on throttle body is unrelated ... i just wanted to know whether replacing a throttle body does require that car computer needs to be reprogrammed
Old Oct 25, 2011 | 10:51 PM
prioris's Avatar
found out that they didn't say "reprogrammed"
the person was told on phone by both a used parts dealer and acura dealer that the it needed to be "relearned". person not sure what that meant. acura dealer told him it would cost $100 dollars to do it.
if i have more info i will let you know
Old Oct 25, 2011 | 10:52 PM
prioris's Avatar
I will and let you know the results
Old Oct 26, 2011 | 05:16 PM
lol $100 to "relearn" the TB? You're doing the same thing by doing a battery reset, the ecu will relearn itself from your driving habits
Old Oct 26, 2011 | 06:31 PM
SupraManAG's Avatar
One custom CL
or just drive and dont reset nothing hence the results in a day or so...
we need to start charging for advice... everyone else is
Old Oct 27, 2011 | 04:42 PM
prioris's Avatar
Question
When the IACV is removed from throttle body, there is a gasket that needs to be replaced. Where can one find the gasket for it.
Old Oct 30, 2011 | 09:15 PM
SupraManAG's Avatar
One custom CL
There are 2 small o rings
No need to change
Ive cleaned mine like 4 times and have never replaced them. You can flip them over if you want to. No real pressure up in the joint
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
012TL-GLM
Oct 5, 2015 06:32 AM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
prbori
Sep 27, 2015 01:37 AM
