Removing rear brake rotor....
Old Aug 21, 2006 | 04:13 PM
ougeta's Avatar
Saiyan Lv.3
Alright, working on my brakes now, going great until I hit the rotors....
there a screw that are on the surface of the rotor, i guess holding them in place.
Anyone know what to do to remove them, because they are pretty hard to remove ????
Old Aug 21, 2006 | 06:43 PM
teh CL's Avatar
ya, their a bitch
i remember when i did mine acouple months back and i strpped like 2 or 3..
so i had to drill them out and man was that exciting
try lubing the living shit out of them and just pray that u dont strip em..
Old Aug 21, 2006 | 08:02 PM
ougeta's Avatar
Saiyan Lv.3
damb, i was praying for the opposite.... I just relized that a guy who did my brakes last time must of stripped one of the screws b/c their is only ine currently present..... fucking mechanics
Old Aug 21, 2006 | 08:32 PM
TexasHonda's Avatar
My understanding is they are not really necessary. If you drill the head away, you should be able to turn out w/ vise grips after removing the rotor. If not, I wouldn't worry.
good luck
Old Aug 30, 2006 | 02:03 PM
slow scoob's Avatar
try using an impact, it worked greatfor me, just tap it with a hammer a couple times, and the screwis loose
Old Aug 30, 2006 | 03:09 PM
Racer510dude's Avatar
I heard heating them up with a torch for 10 min each screw will loosen the screw and can be taken out easily.
Old Aug 30, 2006 | 09:25 PM
CLean 3.0's Avatar
CLeanest in its CLass
follow slow scoobs advice use an impact driver and it should get them right out, if they still wont come out then heat it up with a torch for a minute or two not 10, and if its already too stripped to get a screwdriver on there then use an easy out or reverse drill bit and try getting it out that way.
mada51589
Jan 9, 2025 04:40 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
