Random Stall
Old May 1, 2009 | 12:28 PM
Master Bill Flex's Avatar
Random Stall
Hello Acurazine
I have had my new CL for a month or two now (still need to post pics) and so far everything has been working just as well as my last one... until recently.
A few weeks back, i was casually driving when all of a sudden i go to take a turn and i have no power steering. So im like "wtf", and it says my RPMs are at zero. So as i coast through the turn, i turn my car back on, and drive off. I didnt really think too much of it until today, when it happened again. I was coasting (neutral) down a hill to go to the bank (i was going 30ish in both situations). I go to take the turn to leave campus, and the steering wheel was very hard to turn. My car turned off again. So mid turn i started it back up, put it in gear, and drove off.
So here i am, not knowing what the hell happened or why. If anyone has experienced this before, please let me know whats up before i get in an accident!
Old May 1, 2009 | 01:00 PM
Josh99CL's Avatar
The car only dies after you start to turn?
Old May 1, 2009 | 01:47 PM
im not sure if it does it before, after, or during. I only notice the car is off when there is no power steering.
Old May 1, 2009 | 01:53 PM
Josh99CL's Avatar
Strange... sounds electrical. If you're not getting a CEL (which I assume you're not since you didn't mention it) I'm stumped.
Old May 1, 2009 | 03:25 PM
exactly, no cel, no problems what-so-ever. If this didnt happen, the car would be flawless. Any place i should check?
Old May 1, 2009 | 06:57 PM
Josh99CL's Avatar
You could call a couple shop or an acura dealership and see if they have any ideas off the top of their heads.
I would get under my hood and look for any exposed wiring etc to see if something has the possibility of shorting etc.
Old May 2, 2009 | 08:59 PM
2.3 Fanatic's Avatar
sounds like faulty ignition switch.
Old May 4, 2009 | 10:55 AM
WineRed2.2CL's Avatar
Old School Ridin Clean
check you battery connections.
If not have autozone check your alternator.
Good Luck. Better get fixed before you trickle the effect
Old May 29, 2009 | 07:20 PM
so would you think this is the cause?
http://www.allworldauto.com/recalls/...all_40485.html
Old May 31, 2009 | 11:32 AM
could be when you are turning the powesteering pump is engaged and using more power that's why its turning off.
Maybe your alternator is bad and can't hold up to the strain of when your turning.
So your car is running strong? Just when turning it turns off?
Oh and with that recall try it dude. Call them before you go in.
Old Jun 1, 2009 | 01:03 AM
a2ndragoon89's Avatar
joe rocks c2s :D
check your throttle body bro. i have that same problem.
Old Jun 1, 2009 | 02:55 AM
rice-racer's Avatar
4th Gear
this might help...
http://techauto.awardspace.com/ignitionswitch.html
Old Jun 1, 2009 | 06:40 AM
im pretty concinved that its the ignition switch. The stalling has only happened twice in a 1000 mile period, and i do a lot of city driving. I doubt that turning the steering wheel is the issue, that is because i only notice that the car has stalled once i go to brake and make a turn. I just need to make an appointment for the recall. Ill make an update once it gets repaired.
Old Jun 1, 2009 | 08:50 AM
Tehvine's Avatar
6spd FTW
How many keys are on your keychain?
Old Jun 1, 2009 | 10:39 AM
Josh99CL's Avatar
Old Jun 1, 2009 | 08:19 PM
saiko_cl_duck's Avatar
Old Jun 1, 2009 | 10:06 PM
Old Sep 29, 2009 | 02:24 PM
TMO's Avatar
TMO
I have the same problem. Master did changing the ignition fixed the problem?
Old Mar 23, 2010 | 10:12 AM
97'CL2.2's Avatar
i had this same problem w my 91 acord LX. random stalls with no CEL thrown. I replaced my battery alternator plugs and wires without any improvement. then i replaced the high tension coil and distributor and the problem never returned. hopefully this helps. def sounds electrical though
Old Mar 23, 2010 | 10:33 AM
malice's Avatar
Hi there,
i'm having a similar problem as well with my 97 cl 3.0. My charging/battery indicator came on, eventually my car would not start at all, it ended up being my alternator.
I had it rebuilt with new parts, and the charging/battery indicator no longer came on, car has been running fine. Except yesterday luckily i was down a quiet side street i was driving and started to slow down where the stop sign was, and the car completely shut off, power and everything, no signs or errors on the dashboard before this happened either.
So i put the car in park, turned the key back and then on again, the electronics came back on, nothing was reset (clock, radio, ect), car turned on perfectly and i drove it back home.
I just had the alternator put back in, all wires seemed fine and nothing bad when it was put back in, and the charging system must be working now. I also charged the battery to 100% before driving the car again after the alternator was re-installed.
All i'm saying is lucky i was on a side street, with no-one behind me. Any idea's what could cause the power and engine to shut right off, then the car starts no problems after??
Old Mar 25, 2010 | 10:09 AM
TMO's Avatar
TMO
Originally Posted by malice
Hi there,
My best bet is that the ignition switch is failing like most cases. I had random stalls at stop signs, on the highway and just at times really unexpected. So I went and bought an Ignition Switch at the Honda Dealer, which looks like this: http://www.car-stuff.com/carparts/ac...331427826.html
Or look here: http://www.acuraoemparts.com/delray/jsp/catdisplay.jsp
And find the part number for the ignition switch and there should be the same one for a Honda which wil be cheaper than buying Acura.
Good luck.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
gator90065
Oct 8, 2015 10:14 AM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
