Radio diagram ??
DJ MSR NRG!!
Radio diagram ??
hey guys i searched like a mofo and i found this
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
problem is in my car these wires are not these colors so i dont know which one constant accessiry and illumination can anyone help i got all speaker wires right just cant figure out these which is the constant for the radio which is accessory ???? PLEASE HELP one more question is the clock sussposed to stop working if you take out the stock radio
Illumination should be orange, but I've never even looked through the harness for it (I only use 4 wires when hooking up a stereo: red (12v switched), yellow (12v constant), black (ground) and blue/white (remote)). If you're looking for the 12v constant, it's yellow.
As for the clock, did you check the connections in the back of clock? I know with the 98/99 dash, if you move the console piece enough, those connections can get loose.
my 97 is the same as matt said I am pretty sure. As far as the clock mine still works also with an aftermarket head unit so it must be the connection in the back came loose when you took the factory head unit out. Those wires seem to have just enough play in them where if you pull on one wire another comes loose
The wiring harness is the same for all years of the CL. The only difference I can think of is the amount of play in the wires behind the clock due to the change in dash style. It's been a long time since I did my buddy's 96 Accord, so I don't remember how much play was in the clock wires in that car. I know the 98/99's have plenty of play (I had my dash apart last night putting in a new hu).
I took mine apart last week to change a burnt out light in the "off" switch on the climate control and there isn't very much play in any wire back in there. If it weren't for the adapter to plug into the original harness making the HU wires longer it would be a real pain to even plug the wires into the original HU because the wires are so tight in there
Yeah, I've cut my harness so many times due to changing head units that I have ~1-2" of wire for the constant, and 2-3" of each for 12v switched and ground. I would have very short wires, but the harness for my new hu is basically new, with only a fraction of an inch cut off. So that gives me plenty of space to move the hu before I even think about stretching wires.
DJ MSR NRG!!
yea they are that color on the harness goin into the head unit but coming out of the car is yellow white black red white red and black
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If you figure it out let me know, I have them on my steering wheel, but they're not hooked to anything
found this online, as part of a pigtail harness for the bose decks, enjoy
Yellow – 12V Constant
Red – 12V Accessory
Black - Ground
Orange – Dash Light Dimmer/Illumination
Green – Left Rear Speaker (+)
Green with Black Stripe Left Rear Speaker (-)
White – Left Front Speaker (+)
White with Black Stripe – Left Front Speaker (-)
Purple – Right Rear Speaker (+)
Purple with Black Stripe – Right Rear Speaker (-)
Gray – Right Front Speaker (+)
Gray with Black Stripe – Right Front Speaker (-)
Red – 12V Accessory
Black - Ground
dirleton
08-06-2024 08:19 PM
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
