Problems With My Inside Controls
Old Feb 10, 2011 | 11:34 AM
cbig1969's Avatar
I bought a '99 acura cl from a private owner that had the following functions that did not work:
1. passenger power window
2. door locks (interior)
3. mirror adjustment switch
4. rear defogger
5. seat heaters
6. passenger window switch
7. main switch
8. selector switch
9. courtesy lights
10. vanity lights
11. spotlights
12. trunk light
14. glove box light
I was told by the seller before hand that these weren't working whereby he gave me a group of wires minus a wiring harness that he said needed to be connected/installed in order for any of these items to work which he stated could done in about an hour. Problem is that I don't have a clue where to put these wires. A wiring diagram doesn't do me much good at the moment sense I can't figure out the exact location where these wires need to be attached.
Any help would be greatly appreciated.
Old Feb 10, 2011 | 12:21 PM
derosee's Avatar
Removing the driver side door panel will give you access to the appropriate wires and harnesses for most of your problem. Power window issue could be due to bad motor. Start from the fuses and work your way up. Look up http://www.helminc.com for diagrams. They charge $10 for 3-day subscription.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
