power windows DONT WORK HELP!!!!! PLEASE?
Old Jul 22, 2007 | 08:41 PM
turtle504's Avatar
alright i searched but there was nothing like this.. this is the deal i drive a 1999 2.3CL and just recently the power windows have been giving me problems.
****these are the symptoms****
driver and passenger side windows do not work down
the power mirrors adjuster doesnt work
the lock and unlock doesnt work (on driverside.. but works on the passenger side)
i took apart the door because i thought the plug was just loose but that wasnt the problem and i checked the fuses to see if they blew for any reason. I'm thinking its either the switch or regulator? has anyone ever experienced this problem or know what the problem is? if you do please share thanks
Old Jul 23, 2007 | 10:17 PM
XxAtTheGatesxX's Avatar
Guitarded
Bummer man. My passenger side window gives me problems. Sometimes it wont roll back up, so I just don't risk it anymore. It's pretty common I guess.
Old Jul 24, 2007 | 12:00 PM
saiko_cl_duck's Avatar
sounds like the switches are bad on both.
either go to the junk yard, or look at www.acuraautomotiveparts.org for a new one.
Old Jul 24, 2007 | 09:09 PM
turtle504's Avatar
i couldnt find the switches on www.acuraautomotiveparts.org but i think its kinda strange that both switches went bad at the exact same time.. i was hoping someone has experienced the same problem so i would know what to replace instead of assuming what was wrong with it.
anyone else have this happen to them?
Old Jul 26, 2007 | 03:43 AM
i2paci6270's Avatar
Yea... sad we all are going through the same thing. Haha I drive a 97' 3.0 and my passenger window just went out on me about a week ago
Old Jul 28, 2007 | 11:31 PM
turtle504's Avatar
so its the switch? anyone have any sites where they can purchase them?
Old Jul 29, 2007 | 12:46 PM
just try a drivers side switch. It can cause both to not work, plus it would cause your mirrors to not move.
http://www.acuraautomotiveparts.org/...s=&view=normal
look at #7
Old Jul 30, 2007 | 09:08 PM
turtle504's Avatar
thanks a lot! hopefully it'll work.
Old Aug 9, 2007 | 07:42 PM
turtle504's Avatar
so i just replaced the switch... and it still wont work.. any other ideas!?! anything will help!!! could it be the window regulator by anychance?
Old Aug 9, 2007 | 08:19 PM
could be one, could be both. You've got some weird problems.
Old Aug 10, 2007 | 10:42 AM
turtle504's Avatar
tell me about it!!!! to all to this my idle control valve just went bad!
Old Aug 10, 2007 | 12:15 PM
TexasHonda's Avatar
Common theme in your problem is driver's side door. Mirrors, windows, and door locks are separate circuits but both go to drivers. I would look for damage to the wiring harness either at door hinge or behind door panel. Perhaps something damaged the harness jumper to the door and damaged. Could be damaged connectors also behind door panel.
good luck
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
k6biv
Sep 10, 2015 06:37 PM
ahsm
Sep 9, 2015 08:35 AM
dlknight
Sep 3, 2015 07:54 PM
