Pleasee i need help !
Old Feb 14, 2011 | 11:41 PM
hwdp420pl's Avatar
DJ MSR NRG!!
Exclamation Pleasee i need help !
hey guys i been having the stranges problem that no on can seem to find out why. i have searched and didnt find shit. My drivers side front wheel bearing keeps blowing out every lets say 1000 miles. i have changed the wheel bearing 3 times. so far i have changed the ball joints, tie rods, struts springs, did a alinment after all of that. i understand ghost previous owner changed the knuckles and put on the 98 cl R-O-H set up. i noticed a sound while driving straight like the wheel is hoping but when i turn slightly right it goes away. also when its lifted the whole wheel wobbles. i have ordered new rotors upper controler arms a bearing and hub from Acura dealer i will be installing them soon. please guys Help !
Old Feb 15, 2011 | 12:49 AM
P0401's Avatar
are you sure the axle is torqued correctly? I have seeen this happen before but it was usually because the axle wasn't allowing the bearing to seat correctly
Old Feb 27, 2011 | 09:40 PM
hwdp420pl's Avatar
DJ MSR NRG!!
im pretty sure it is i just replaced the knuckle, hub, bearing, all joints and arms, can the axel be bad how do i know if it is putting pressure on the bearing i have a h22 swap does anyone know the part number on the axels i need if im correct its accord ones ? what elese man im getting ready to go crazy i dumped so much money and still nothing its horrible
Old Mar 26, 2011 | 11:03 PM
hooptyswerven's Avatar
6th Gear
2 questins
1- how is your wheal alighnment
2- more of not a question but your knukle arm can be bent thats what happened to me...
got new one from oeacura aprts for under 200$ ide say this is your best bet ive bin there...
Old Mar 26, 2011 | 11:12 PM
6th Gear
are u the one doing the bearing to hub installation? dont mean to be fresh but u can be doing something wrong if not seated flush can cause the bearing to fail-- clean hub with sandpaper fine grit... when installing put some w/b grease for easier installation.
kaNo
Jan 13, 2013 10:27 AM
bigg_86
May 28, 2012 09:09 AM
Phidboi
Feb 28, 2011 10:35 AM
MatthewHoang88
Dec 7, 2010 02:36 PM
7 Tl
Nov 30, 2010 08:41 AM
