PCV valve for 2.2
Old May 28, 2006 | 06:58 PM
jdalton's Avatar
PCV valve for 2.2
i just got some seafoam and want to use it on my 2.2 cl but couldnt find anything helpful to locate the pcv valve on a 2.2 after searching for half an hour. i need some picture or good description cause i really want to clean that shit out
Old May 28, 2006 | 09:07 PM
Mach30SiR's Avatar
Bagel Bomber
pull on the hose that is attached to your valve cover above the "V" in in Vtec, it will pop right out, its a block piece of plastic with a 90 Degree bend in it.
Old May 29, 2006 | 09:21 AM
Mach30SiR's Avatar
Bagel Bomber
yeah i was right, above the V
Make sure you have it being sucked into the intake manifold and not the heads though.
Old May 29, 2006 | 12:14 PM
jdalton's Avatar
thanks a lot for the reply... now i just got to get up to do it
Old May 29, 2006 | 12:22 PM
Mach30SiR's Avatar
Bagel Bomber
yep, no problem. but yeah make sure you dont pour it in the pvc whole, make sure it gets sucked into the intake manifold. you sould clean your pvc valve while its out, or replace it, they are like 3 bucks.
Old May 29, 2006 | 02:03 PM
jdalton's Avatar
is the car supposed to smoke after doing the seafoam in the crankcase cause mine didnt...
Old May 29, 2006 | 07:44 PM
Mach30SiR's Avatar
Bagel Bomber
in the crank case, no. your soposed to put 1/3 of the can in the crank case, 1/3 in the gas tank, and 1/3 though a vac line that will allow it to be sucked into the intake manifold. The 1/3 in the intake manifold will smoke after you let the car sit and start it up. read the diy
Old May 30, 2006 | 11:00 PM
jdalton's Avatar
yea i did all that and i workd out fine.... i did them all separately, pcv first, crankcase second, and gas third.... car smoked during driving like it said on the diy.... thanks for all the help.
Old May 30, 2006 | 11:05 PM
Mach30SiR's Avatar
Bagel Bomber
werd, rock on
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
