parking brake light will stay on need help
my parking brake light stays on but not that bright iv read threads but none are the same to my problem
the light stays on maybe half bright. the brake fluid is up to its limit. the light stays on when the car is warmed up. i feel as if the brakes are slowing the car down when crusing on neutral. my brakes dont squeak.
does any one know what it could be?
Try unplugging the float sensor in the master cylinder reservoir. If this cause light to go off, you have a bad float sensor switch. New switch should fix.
If that doesn't work, check the emergency brake switch which could be sticking open w/ a weak contact.
good luck
good luck
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
