p1382
Old Jun 10, 2014 | 01:06 PM
schulte's Avatar
Exclamation p1382
Hello fellow acura people! Thank you for taking time to read my post. I have a 98 CL 2.3l and I keep getting a p1382 code (cylinder position sensor no signal) I have replaced the distributor, ohmed the wires and they were at about .3ohms and checked the voltage drop by putting 12v on the two cyp wires on the dizzy connector then checked them at the ecu connector to make sure there was continuity. I reset the timing and replaced the computer. The same code keeps coming back. Any ideas? I'm stumped and I need help.
Old Jul 2, 2014 | 08:44 PM
Showmeyourtints's Avatar
How's your gas mileage? Does the car sputter or have an idle issue? I was getting that code along with several more and found out my car had a bent exhaust valve.
Old Jul 9, 2014 | 02:50 PM
schulte's Avatar
Thumbs down
I just bought the car and I havent really noticed bad gas mileage. The car just hesitates when you are accelerating at certain rpms under load.
ArTL-S
Jun 4, 2011 01:04 AM
