Overheating with AC on & speedo problem
Old Sep 25, 2005 | 01:31 AM
RedX's Avatar
97 Acura 2.2CL 160k miles
Exclamation Overheating with AC on & speedo problem
Whenever I run the AC the car overheats, not all the way into the red but close. theres plunty of fluid and its fine without the air on.
My speedo is way off, ill be in 3rd gear at 3000 rpm and the speedo says im going 60mph.
Old Sep 26, 2005 | 12:58 AM
wilp99's Avatar
sounds like the a/c fan isnt commin on. could be a bad relay or fuse. i would also change the thermostat just to rule that out. and thats pretty cheap and prolly needs to be done anyways.
Old Sep 27, 2005 | 12:11 AM
RedX's Avatar
its kinda weird because today it ran fine, no overheating at all.
Old Sep 27, 2005 | 07:35 PM
recycledpaper's Avatar
3rd gear 3000RPM, i think that is 60MPH isnt it? or it could be around the 55's, either way i think it should be pretty acurate, you can find out by stopping and seeing if the idle moves the needle
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
