Over Heating
Old Oct 30, 2007 | 05:58 PM
Shoshinsha_KiDs_CL's Avatar
sold!
Over Heating
question.. sometimes when i drive pretty hard and i let my car idle for a bit, the temp will go way high like almost near the H point.. i was wondering if i put more coolant, will it help? im a bit worried. but it only happens sometimes.. help please!!
Old Oct 30, 2007 | 06:01 PM
AznX TL's Avatar
where is....
are you leaking coolant? or maybe the fans just arent kicking on.
Old Oct 30, 2007 | 06:07 PM
sold!
nah not leaking. and fans are on when temp rises.. just weird how it goes way up there..
Old Oct 30, 2007 | 06:21 PM
AznX TL's Avatar
where is....
im thinking it might be the thermostat.
Old Oct 30, 2007 | 06:25 PM
lnsyone's Avatar
CL 4 LYFE
or rad cap
Old Oct 30, 2007 | 06:42 PM
G22_Powered_YA1's Avatar
well if your coolanyt level is fine, then id move on to thinking fans or thermostat.....
I mean if it only goes up after you go on a hard run id assume the fans might not be working at 100% efficiency (fancy way of saying the fan is dying, but not dead). thats what happened to mine not too long ago, just replaced the fan motor for like 50 bucks, and the the temp has stayed at its normal mark ever since
Old Oct 30, 2007 | 07:40 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Thermostats are notorious for going in CL's
Old Oct 30, 2007 | 09:14 PM
DaInFaMMuS1's Avatar
Either your thermostat or your radiator. Those were the symptoms of mine when they went out
Old Oct 30, 2007 | 10:41 PM
white2.2cl's Avatar
before i got a new radiator fan i would tap the back of it and it would start right up but yea $ 50 bucks gets you a new fan which = no headaches
Old Oct 30, 2007 | 11:24 PM
sold!
well my fans are brand new.. and my radiator was changed like 30k ago and im going to put more coolant tomorrow morning.. a guy from kragen said it might be my thermostat. btw has anyone put a switch for the fans to go off and on??
Old Oct 31, 2007 | 10:33 AM
white2.2cl's Avatar
putting a switch to the fan is not hard but i wouldn't recommend it i mean why put a switch when its suppose to turn on by itself sounds like a hassle to me try checking the fuses, put some more coolant, check your oil, and just to be safe check connections to the fan mysterious things do happen if none of those problems i guess for sure thermostat
Old Oct 31, 2007 | 11:45 AM
asianspec's Avatar
Mike,why would u put a switch for you fans? and when u coming up here again?
Old Oct 31, 2007 | 11:48 AM
(Mid-Atlantic)
There's a fan control switch stock, I wouldn't mess with it.
Old Nov 2, 2007 | 02:23 PM
sold!
kool kool thanks guys! well im gonna be in Santa ana this sunday! im dropping off my volks. i sold them to some dude on here. wanna meet up?? ill be there lik around 1pm.
Old Nov 2, 2007 | 02:38 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
Dude fans are only needed when ur not moving..
its DEF ur thermostat..
Old Nov 2, 2007 | 02:39 PM
sold!
wanna help me change it!?
Old Nov 2, 2007 | 05:39 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
when and where?
And how?
Old Nov 2, 2007 | 05:45 PM
sold!
lol i dont know how to change it lol! does anyone here??
Old Nov 2, 2007 | 06:07 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
bump
Old Nov 3, 2007 | 06:31 PM
rice_plz's Avatar
Car is Back
hey, Shoshinsha_KiDs_CL
sorry for the hijack but ur msg box is full i cant sent one to you thanks
Jr.
Old Nov 3, 2007 | 10:48 PM
nickbeee's Avatar
read this:
https://acurazine.com/forums/showthread.php?t=191449
and make sure you use an OEM tstat if you replace it!
Old Nov 9, 2007 | 12:11 PM
sold!
kool thanks bro!
Old Nov 14, 2007 | 10:13 PM
bRunCL's Avatar
if ur car is overheating u can try turning the heater on high and it will usually cool down a little (this isn't a fix its just a temp solution)
Old Nov 14, 2007 | 10:24 PM
AznX TL's Avatar
where is....
that only works if the fan isnt working, and you're suppose to turn on a/c not heat. when you turn on the a/c, the secondary fan will kick on.
Old Nov 15, 2007 | 03:22 PM
bRunCL's Avatar
AznX TL wouldn't turning on the a/c make the engine work harder? I thought that if you turn on the heat then ur heater core redirects the heat just as the radiator does.
Old Nov 15, 2007 | 06:41 PM
AznX TL's Avatar
where is....
huh, looks like you're right and i've been doing it wrong the whole time.
Old Nov 17, 2007 | 10:48 AM
runyun's Avatar
You're right. I cant think of any instance where turning on the a/c would lower coolant temps down. If you're already overheating - you ecu should have kicked on both fans by that point.
Turning on the heater - would open up coolant to the heater core... acting like a seperate cooler. But it's only a temp fix and depends on the situation
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
