oil pan leakage thru two bolts
after getting a tranny flush and coolant flush on my 98 Cl the autotech said something about the oil leaking out of two bolts in the oil pan the drain plug and another bolt pls help?
our transmissions are very finicky and the only thing I know to mention would be change the gasket on the pan. Also make sure they changed the crush washer on the drain plug (I think the transmission has one like the oil does). it may be a lose bolt that you can get under it and see if you can tighten before you drop the whole pan to change the gasket but chances are when you had it flushed it flushed out something that was helping seal the pan and now the gasket needs to be changed. I have read some people who's cars were running fine until they had their transmission flushed and then their transmission started acting up and finally went completely out, as I said our transmissions on these cars are very finicky
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sounds like you need a new oil pan
IBankMouse
06-13-2020 12:53 PM
