Oil Leak
Old Jul 20, 2006 | 02:15 PM
utstrat03's Avatar
Oil Leak
My girlfriend’s 97 2.2 CL has an oil leak. I didn't use a Honda oil filter just a regular one from AutoZone. Is this more than likely the problem? I checked the crush washer on the oil pan and it definitely was not leaking. Besides it looks like the oil is somehow running and dripping off of the transmission. I checked the oil on the ground and it is definitely engine oil and not transmission fluid. Any possible causes. I just changed the oil almost two weeks ago and it is almost out of oil.
Old Jul 22, 2006 | 11:47 AM
saiko_cl_duck's Avatar
check for a hole in the oil pan, may not be that big, but i could do it. Also, check all the oil lines, one could be loose or have a crack in it.
good luck
Old Jul 22, 2006 | 01:58 PM
TexasHonda's Avatar
Check around valve cover. Check around Vtec solenoid valve.
Check around distributor base. The distributor shaft oring can crack and leak a substantial amount of oil.
Check the oil pressure sender unit on the back side of the engine. These have been known to leak badly.
good luck
Old Jul 22, 2006 | 05:23 PM
Cocoa's Avatar
2600lb CL
Sounds like the Rear Main Seal, since it's leaking from the where the tranny and block meet.
Old Jul 23, 2006 | 08:09 AM
TexasHonda's Avatar
Oil leaks can be very difficult to trace. Where the oil drips off the engine can be a indicator, or not.
It helps to clean the engine carefully and then watch closely for the leak. More high tech is to add a UV dye to the oil and use a black light to trace the leak.
good luck
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
