Noise from passenger side when stopping
Anyone have this problem of a clicking sound from the passenger side door.
It sounds if something is loose in the door every time i brake and go, something seems to move
At first i thought it was my glovebox then thought seatbelt was banging the side plastic panel, also thought there was something in my door pocket containers nothing. Fasten my seatbelt passenger side removed everything from glovebox, and checked underseats for loose stuff, still the problem exsists. Can something come loose like a piece of plastic, or nut inside the passenger door. I would hate to take the door panels off and remove all the plastic protective sheet then find nothing in the door.
.At first i thought it was my glovebox then thought seatbelt was banging the side plastic panel, also thought there was something in my door pocket containers nothing. Fasten my seatbelt passenger side removed everything from glovebox, and checked underseats for loose stuff, still the problem exsists. Can something come loose like a piece of plastic, or nut inside the passenger door. I would hate to take the door panels off and remove all the plastic protective sheet then find nothing in the door.
Try pushing your passenger seat all the way towards the front of the car or not all the way back. I had the same problem. The sound disappeared after I moved the seat forward a bit. It seemed like the seatbelt was hitting the seat panel when the seat was fully back.
Pushed the seat forward and no click or banging noise...Thanks
marcelft
Jul 10, 2018 06:17 PM
Oct 21, 2015 11:38 PM
sockr1
Oct 1, 2015 01:31 AM
