no spark....
Old May 27, 2014 | 05:51 PM
TampaCL813's Avatar
no spark....
OK guys I need help. I have a 97 3.0. I have just finished doing my trans swap but now I have so spark. I've triple check the ground on the thermostat, disconnected the wiring harness and reconnected it. I scanned it and pulled p0700, p1768, and p1773. I looked up all the codes and found one common problem and its electrical. I have no spark out of the coil and no spark at the distributor. I did have to replace the distributor Cuz it was leaking oil and I also busted the module during the swap. Is there any other grounds I'm missing? Anyone deal with this before?
Old Jun 3, 2014 | 11:32 PM
TampaCL813's Avatar
OK. Bad module. Exchanged it and it fired right up. I'm proud of myself first successful trans swap
