Newly purchased 97 Acura CL tranny question
Hey everyone I just bought a 97 CL 2.3 4 speed auto. It's got 170K miles but it's been kept in unbelievably good shape. I need some questions answered about the tranny - I'm heading to the dealership to pickup some ATF..
1. Where can I find a guide to drain and refill the tranny? I don't know if the car needs to be on while I'm draining, how much will drain, how much do I put back in (I know it's 3 quarts but will all 3 quarts come out when I open the drain plug?)
2. Can I fill fluid through the dip stick for the tranny?
3. Do I check the fluid level for the tranny while the car is running and fully warmed up?
Does anyone recommend any additives? I feel like the tranny holds 3rd gear a bit too long sometimes.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Searching around will help you find a lot of answers to these questions, here's a pretty good thread
https://acurazine.com/forums/showthr...y+fluid+change
You don't want to fill through the dipstick, there's a bolt on top of the tranny 17 mm I believe
Check fluid while car is off
(Mid-Atlantic)
(Mid-Atlantic)
I don't know for sure since I have the 3.0, but I thought the 2.3 had a bolt as well
The drain and fill isn't bad for a diy, I had to do it in a parking lot on a road trip, when my tranny seal was leaking, I had to stop in VA and fill my tranny, took like 5 mins
Drive the car to operating temp (Untill the radiator fan comes on). Turn the engine OFF! Make sure the car is on level ground and in PARK. Then drain the fluid through the 18mm plug. Make sure to replace the o-ring on the plug as well or you will risk leaks. If you want to flush the ATF then that will require lots of ATF fluid and another post.
CL in lawnmower status
I jacked up the car to change tranny fluid but there is no 17 mm bolt for draining the fluid. I saw another kind of thing, one that needs a big allen type screwdriver to open and is round. Any ideas guys?
i was talking to a mechanic about three days ago and he said it was never a smart idea to do tranny fluid changes on high mileage automatic transmissions. i think you should look into that before you do anything to your car, cause you might f#*k it up. hopefully not though! good luck!
IIDXholic
10-08-2015 07:53 AM
NewtoAcura11
09-28-2015 04:40 PM
