Need Help
Old Jan 22, 2009 | 02:46 PM
shoisfaster's Avatar
Need Help
I have a 1998 cl 3.0.My transmissions slips in all gears but still works, i have a engine light on but no trany light flashing..need help please
Old Jan 22, 2009 | 07:20 PM
DoubleSh0t's Avatar
Go to an automotive store like Advanced Auto or whatever's in your area and have them pull the code. It's free. Don't be surprised if your trans is toast though.
Old Jan 22, 2009 | 07:46 PM
transmission fluid
I checked the tranny fluid and its over the fill line could that be the problem??
Old Jan 22, 2009 | 07:52 PM
tranny fluid
i checked the tranny fluid and its over the fill mark, could that be it ??
Old Jan 22, 2009 | 07:54 PM
tranny has to much fluid in it..could that be the problem??
Old Jan 22, 2009 | 08:10 PM
i checked the trann fluid and its over the fill mark can that be the problem
Old Jan 22, 2009 | 08:14 PM
mitch14's Avatar
CL in lawnmower status
^dude you haven't even waited a half an hour for a response, and there's not that many ppl on, you have 3 reposts, that won't make ppl want to reply, it'll make them want to you
and it's just plain rude IMO
and since you only have 5 posts total, that means in 60% of your posts you repeat yourself
Old Jan 22, 2009 | 08:25 PM
DoubleSh0t's Avatar
Yes, an overfill is a problem - but I can't say that's the reason you're getting a CEL.
How did you check the fluid?
Old Jan 22, 2009 | 08:45 PM
tranny problem
i checked it when the engine was warm, put it in park while in idle and checked the fluid.
Old Jan 22, 2009 | 08:57 PM
I did disconnected the battery to resest the computer..drove around for 45 min and the cel didnt come on.
Old Jan 22, 2009 | 09:42 PM
DoubleSh0t's Avatar
You're still getting slippage though? I'd suggest draining the fluid (all of it), and refilling to the correct level. Don't take it to a place for a flush - drain and fill only.
Someone correct me if I'm wrong, but the code for the CEL should still be stored, regardless if the CEL is on or not. Which means you could still get it checked.
Old Jan 22, 2009 | 10:15 PM
i heard that over flow will make aerlated, is that true..thanks for all oyur help.
Old Jan 23, 2009 | 06:44 AM
TexasHonda's Avatar
Find out what codes are set. This may provide a clue to your problem.
good luck
Old Jan 23, 2009 | 10:57 AM
DoubleSh0t's Avatar
Overflow can cause aeration, but a lot of people in the community disagree on what that affect on the transmission is.
I was always told that overfill = increased pressure which leads to premature failure and part wear. But there are plenty of people that will disagree.
Pull the codes and let us know what they are like TexasHonda said.
Old Jan 23, 2009 | 06:24 PM
iI went to autozone to get that code pulled and found out that here in california, that they past a law agianst the free code pulling cuz auto companys bitched about losing money..thats bullshit.
