power steering question
Old Jan 23, 2009 | 11:38 AM
smokinhay's Avatar
4th Gear
I have a 98 cl 3.0 and my power steering pump is in bad shape, it makes a horrible whine, has no power, and upon inspecting it there were little metal grindings all in and around the power steering pump pulley, the fluid is probably dirty as hell but the fluid is at the proper level, could this be the problem, or is the pump beyond repair, and if so most importantly is there any way to run the car without a power steering pump, and just use it manually?
Old Jan 24, 2009 | 07:25 AM
TexasHonda's Avatar
Go get a used pump and install. You should be able to repair for <$50. Use car-part.com to find a part near your zip code.
Suggest replacing all fluid and reservoir also (trash might get by filter).
good luck
Old Jan 24, 2009 | 02:43 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
replace the pump and replace all fluid
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
