My Brakes....
Old Jun 28, 2009 | 12:50 AM
acura_honda_30cl's Avatar
My Brakes....
ok idk what the hell is going on...but everytime i press my brake like when im going about 20mph or so...then i press my brake to slow down it vibrate...whats the cause of this? is the rotors warp or the brake pads are warp? or 2nd my back struts are gone its like when i hit a bump it bounces....QUOTE" this is not my car its a friend car"
Old Jun 28, 2009 | 12:54 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Does the steering wheel shake? Do you feel vibration through the brake pedal? If so, most likely the rotors are warped.
Old Jun 28, 2009 | 01:30 AM
i feel it threw the pedal
Old Jul 14, 2009 | 09:21 PM
whiteyy97CL's Avatar
if you feel it thru the pedal the back rotor(s) are most likely warped. if you'd felt it in the steering wheel its likely that the front(s) are warped
Old Jul 16, 2009 | 08:33 AM
Eband27's Avatar
pedal vibration can indicate front OR back rotor warpage. Usually rear discs are not prone to being warped because of the 70-30 brake distribution in fwd cars. It is possible, but unlikely. To eliminate rear disc warping, try applying the handbrake slightly while driving, if u feel a vibration when applied, the rear rotors are warped.
Old Jul 16, 2009 | 09:58 AM
Anhedonia's Avatar
^^ make sure you check that your ebrake releases before you do that while driving though. as most new england member know our rear caliper arm assembly and the spring that releases it tends to rust and seize the caliper. not letting it release.
TL-GIXXER
3G TL Photograph Gallery
May 20, 2015 06:14 PM
sebas809
Dec 14, 2009 01:22 PM
arrior
48
May 25, 2008 02:26 PM
mzahidi
34
Jan 18, 2008 08:07 AM
lilvanmuzz
1G TL (1996-1998)
20
Oct 31, 2007 07:42 PM
