Lights on chime
Lights on chime
I own a 1998 3.0 CL that recently started having the problem of the "lights on warning chime" sounding when I open the drivers door whether the lights are on or OFF.
Has anyone had this problem and know of a fix?
I have a Chilton's Acura paperback manual and a downloaded CL service manual but neither has enough schematic detail to show where the sensor for this circuit is located. I'm not sure if the HELMINC.com electrical manual would be any better than what I already have, especially for $40.
Any suggestions?
Thank you, Dale
Any suggestions?
Thank you, Dale
In my Acura the key in the ignition warning sound and the lights on chime are different.
The lights on chime is an alternating ding dong sound, a key in the ignition warning sound is a repeating 4 quick chirps with a pause between.
The key in the ignition warning over rides the lights on chime so only the key in the ignition warning is heard, until the key is removed.
B A N N E D
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
btw for the actual sensor, i think it is in the BCM/fuse block (i think normally called the multiplex control module) on the driver side kick panel
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
