Leaking water and squeaking
Old Aug 25, 2009 | 06:40 PM
Safzal's Avatar
Hey guys, I just got my CL yesterday, debadged her today
Anyway, I noticed a puddle of water on my garage floor, took a peek under the car and it was dripping from under the center console area. I ignored it, thinking maybe it was just extra water from when i washed my wheels earlier, but it wouldve dried up in this extreme heat.
On my way home about an hour later, i noticed a slight squeak while driving very slow, just for a second when i tapped the gas. When I was parking in my garage, as I was slowing down I heard kind of a draining or grinding noise.
The only things I can think of are an a/c water leak (although i think the leak would be inside the car if this was the case), or worn brakes (because of the squeaking and grinding sound). But neither one of those explains the other.
I got the car from a Honda dealer just yesterday, so I would assume the brakes arent worn, but I'm looking for a second opinion.
Any thoughts? Thanks in advance
Old Aug 25, 2009 | 06:51 PM
Anhedonia's Avatar
3.0 or 2.3? auto or manual?
Old Aug 25, 2009 | 07:12 PM
Safzal's Avatar
3.0 auto.
Also, I meant to post this in the Problems & Fixes area, not DIY, sorry
Old Aug 25, 2009 | 07:40 PM
Ron A's Avatar
Administrator
Welcome to the forums.
Moved to Problems & Fixes.
Old Aug 25, 2009 | 07:45 PM
Anhedonia's Avatar
well, chances are your trans is fucked up. how many miles? 3.0 trans go incredibly often unfortunatley. they are made of glass after all. you could be looking at a trans seal leak, which would cause the puddle, also the lack of fluid could cause the grinding etc. tonight/tomorrow, check the trans fluid level, report back.
Old Aug 25, 2009 | 08:49 PM
Safzal's Avatar
shit, i hope thats not it. ill check tomorrow. It only has 62k miles, which is pretty much why i bought it
Old Aug 25, 2009 | 08:57 PM
Anhedonia's Avatar
well you should be in the clear then, but then again, 12 year old car is 12 years old and those 62k miles could have been seriously hard driving.
Old Aug 25, 2009 | 11:13 PM
Safzal's Avatar
i hope so. Ho much would it cost to fix/replace if that turns out to be the problem? Just checked it. I dunno if all CLs have the transmission fluid dipstick like this, but mine doesnt have the usual etched marks, it has two small holes, and the fluid is at the upper hole.
Old Aug 25, 2009 | 11:26 PM
Anhedonia's Avatar
you should be good on trans fluid then. did you check all your other fluids? also, the grinding noise you can be hearing COULD be caused b your brakes, especially if the pads are down to metal. regardess of whether i was applying pressure or not, my pads were grinding right before i just replaced them.
Old Aug 25, 2009 | 11:38 PM
Safzal's Avatar
The grinding was very faint, maybe i was just being paranoid cuz of the squeaking earlier. Ill check the brakes tomorrow though. Keeping my fingers crossed that the water was just from the a/c.
Thanks for all the help
Old Aug 26, 2009 | 07:55 PM
bRunCL's Avatar
I would drive the car with no ac at all and check to see if you still have a leak....Run you finger through the puddle and see if its water or thicker(trans fluid, oil)
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
