key/ignition problem Acura CL 2.2 1997
Hello Guys,
I’ m having a problem and was wondering if some know about the solution. I wanted to use my car like usually in the morning today and I couldn’t turn the key in the ignition. The key is at lock and there is no way to turn it even to the accessory position.
I tried everything (turning the steering wheel while turning the key, I played in the speed control, open/close door) and nothing seem to work.
I heard that changing the ignition is very expensive, is there any idea ?
Thanks lot
Thanks lot
did you try jiggling the steering wheel (not turning, "jiggling") while turning the key?
It sometimes happens to me when i park over night and too lazy to straighten the wheels...
If that's not the case than i think there's an ignition recall for the 97... search!
Edit: if your key cylinder is busted, you can buy a replacement online and install it yourselves, it's an intermediate to hard job (a 7 out of 10 difficulty)... but not impossible.
Thanks Sleep_DEPRIVED_Sleeper and AznX TL, your advices helped me lot. After jiggling while keeping pressing on the key for a couple of minutes the key finished by turning and the car turned on. But the problem is still there because when I took off the keys I had to jiggle again to be able to turn it. I guess I have to change the ignition.
Apparently there is no used ones in the area of Montreal. Which website do you advice for buying ?
Again thanks for the advice
no problem, try oemacuraparts.com.
I don't know the exact name of the part you need though, I want to say "ignition switch" but it's probably wrong....
PM TexasHonda and ask him what you need!
Zonian22
Nov 14, 2015 01:20 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Zonian22
Sep 2, 2015 08:19 AM
