Junkyard Engine...
Old Oct 29, 2009 | 04:49 PM
fromztosuv's Avatar
Junkyard Engine...
Im replacing my engine with one from the junk yard that has 75k mile on it (so im told).
Is the vin # on the engine & if so where may I find it.
I have a five speed so does it matters if the replacement engine comes from a automatic?
My engine is a F23A1, is this the only thing that has to match up?
Should I replace water pump & timing belt before installing new engine?
All additional info DEEPLY appreciated...
Old Oct 29, 2009 | 06:54 PM
bgsrmyth's Avatar
The vin# should be on the vehicle itself and not the engine (correct me if I am wrong). As for the motor, it doesnt matter that it came off an automatic you can use it. I am doing the same thing as you, my replacement motor came off an automatic Accord with the same engine. Just to be safe, I would replace the timing belt and water pump. Those are two things you definitely do not want trouble from.
Old Oct 29, 2009 | 11:37 PM
Polaris573's Avatar
1998 CL 3.0
There is a VIN number on the engine. Should be stamped near the same place the model number is (F23A1).
Old Oct 30, 2009 | 04:57 AM
fromztosuv's Avatar
I looked on my current engine (which was never changed before) by the F23A1 & I see several numbers stamped on it but none of them match or even partially match my vin.
Is it in a code or somewhere else?
Old Oct 31, 2009 | 12:05 PM
Polaris573's Avatar
1998 CL 3.0
I went outside and looked at my car and realized I was thinking of my old one. Sorry, I don't know where it is on the CL.
Old Oct 31, 2009 | 03:23 PM
incredulous1's Avatar
its by the lower driver side of the windshield or the door jamb
Old Oct 31, 2009 | 07:54 PM
Tehvine's Avatar
6spd FTW
There are sometimes VIN's on the back of honda motors, but generally just on the car. If it's on the back, it will be on a green tag to the left of the oil filter.
Old Jun 18, 2010 | 11:56 AM
fromztosuv's Avatar
New Engine
Hello All...
My engine died in May & I just had her replaced with a Japan engine with only 60k miles on her... I was also given a 12 months / 12000 miles warranty!
She feels NEW & so I'm back!
Old Jun 18, 2010 | 12:35 PM
P0401's Avatar
I know the vin is stamped near the starter on chevrolet motors and on the block next to the goose neck on big block mopar motors. I am sure there has to be some numbers on foreign vehicles also but not sure where they would be located
Old Jun 18, 2010 | 01:36 PM
senatorcliff's Avatar
5th Gear
Good deal fromztosuv! Did you do it yourself and did you have any problems with emissions? Isn't the Jap engine rated at a high horsepower?
Old Jun 18, 2010 | 03:46 PM
fromztosuv's Avatar
I had EVERTHING done! Passed emission with no problems. It cost me $1400 but the car is in excellent condition (WORTH EVERY DIME) & it feels pretty SMOOTH & POWERFUL...
xsilverhawkx
Sep 28, 2015 06:51 PM
ibGTV
Sep 28, 2015 03:40 AM
RedTSXinWashington
Feb 16, 2008 01:27 PM
zigzagzig
Feb 3, 2006 07:46 AM
Vegeta1
Aug 20, 2002 11:17 AM
