J32A2 on a 4-speed tranny 97 cl 3.0
Hi. I need your help. Im new here. I recently had my j30a1 swapped for a j32a2 but since i have a j30a1 ecu. I had to use distributor ignition. Had to get the 1 cam on the j30a1 and swap it with the j32a2 rear bank cam for the distributor to work. Plus i had to use the lower and upper im and tb of the j30a1. So im kinda running a half baked j32a2 setup. How do i go about this. If i use a j32a2 ecu will the 4-speed at be compatible or do i need some mods. What harnesses do i need? Anything else beside that? Thanks alot call me 661-8037262
frank
frank
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
