Issue with Starting
Old Sep 10, 2008 | 05:49 PM
mitch14's Avatar
CL in lawnmower status
Issue with Starting
So for the last couple of days, when i go to start my car in the morning, i push in the clutch turn the key all the way, and there is no sound at all, the car will eventually start after a couple seconds, but there is no cranking sounds or anything else for that first little bit. Oh and the car is a '97 2.2 5 spd. Also i do have a stereo system in it with a capacitor, and i think the capacitor may be draining power from the battery overnight. If this is the issue though i should hear the starter clicking trying to turn over the car though right? Any ideas or help is greatly appreciated
Old Sep 18, 2008 | 07:30 PM
TexasHonda's Avatar
No action when keyswitch is turned suggests two possibilities; poor battery wire contact (remove and clean thoroughly) or faulty keyswitch assembly. Check cables first, if those are good, then keyswitch is likely. Sometimes a test light on the blk/yel wire to the distributor connector is necessary to confirm the keyswitch is failing.
No capacitor(not even a thumper booster or whatever they call them) could drain a battery. It will charge w/i a few seconds or a minute at most and then is an open circuit.
good luck
Old Sep 25, 2008 | 11:46 PM
1998cl23's Avatar
your clutch safety switch could be failing and making it not start or like texas mentioned a poor connection will resemble what you are describing,
btw dont waste your money on capacitors they are useless junk.
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
