installing a different airbag model
Old Nov 9, 2009 | 09:29 AM
syain's Avatar
I want to replace the passenger airbag. I got a used airbag from a junk yard with the same color but different model #.
Is it okay if I install this airbag?
Old Nov 9, 2009 | 03:43 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Should be ok, as long as it's a honda airbag and has the same plug, I swapped a 99 airbag onto my 97, and it worked with no problem, just make sure that the battery has been disconnected for at least a half hour before messing with airbags
Old Jan 27, 2010 | 03:01 PM
Lawlergaggzorz's Avatar
i'm looking to replace my airbags too XO
Instead of replacing my bag in the driver's side i'm lookin to get a Momo wheel. If i ONLY replaced the module and side airbag would it still cause the srs light to come on? I know once you unplug either of the aigbag connectors it automatically shorts the connector out...
Old Jan 27, 2010 | 03:28 PM
(Mid-Atlantic)
What side airbag? Driver side or passenger? If you remove the driver side you will need to get an srs trick module
Old Jan 27, 2010 | 03:41 PM
sorry i meant passenger. where can i find a trick module?
Old Jan 27, 2010 | 04:46 PM
OttaWacK's Avatar
less n00bin more g00glin
Go behind the dash and unplug the SRS light.
Old Jan 28, 2010 | 05:06 PM
That sounds more like it
lidobitesize
18
Oct 22, 2016 10:21 PM
EvilVirus
Dec 10, 2015 07:38 PM
IIDXholic
Sep 19, 2015 10:18 AM
Sep 14, 2015 10:09 PM
