Here we go again - Radiator fan questions
Old Aug 18, 2016 | 10:03 AM
Gigolo's Avatar
1999 Acura CL 2.3
well im back with another question or 2
which fan is the one on the driver side??
should the fan on the driver side (dont know which it is but its the one without the motor behind it) go on when the a/c is turned on?
where is the temp sensor located exactly??pic would be awesome
the passenger side is working fine..if it wasnt for that id been overheated..was at a long light right before i got on highway and temp guage went to the middle (if it ever goes there something aint right in this car) and when i sped up it went down a lil and i made it home..
just trying to cut to the chase and mayb get whatever is broken part-wise today..
i already tested the relay and fuse..both good..now i guess its either the fan itself or the temp switch
anyhelp would be cool
thanks again
99 acura cl 2.3
Old Aug 22, 2016 | 09:08 AM
mossman77's Avatar
The radiator fan (driver's side) on my 2011 TL never comes on and I have yet to figure out why. The passenger's side fan is the A/C condensor fan, so yes, it should cycle on/off when the A/C is on. For you, I would start with checking the coolant level, making sure there is no air in the system, and perhaps replacing the thermostat and see if that helps.
Limitless
Aug 7, 2020 07:26 PM
Ac Attack
3G TL Photograph Gallery
53
Oct 28, 2016 10:10 AM
brewhaha1220
Jun 3, 2016 08:49 PM
Enrick Gatien
Apr 3, 2016 10:26 AM
prepreludesh
Mar 16, 2016 12:25 PM
