Having issue with my power seats driver side
Old Jun 23, 2011 | 05:33 PM
Tawny's Avatar
4th Gear
Sorry if i put this in the wrong thread, i have a 1998 cl 3.0, the seat will only move forward per the switch. when i try to move it back i get nothing. i checked the fuses and it looks good. do you guys have any suggestion?
Old Jun 23, 2011 | 06:12 PM
Ron A's Avatar
Administrator
Welcome to the forums.
I moved your thread to the 1G CL Forum, which is more applicable to your car.
Old Jun 23, 2011 | 07:25 PM
97'CL2.2's Avatar
check the tracks...could be just some loose change wedged in there
Old Jun 24, 2011 | 01:08 AM
P0401's Avatar
when I first got my 97 I had the same problem, it would move backwards just a click and stop but if I did it about a million times I could get it to go forward with ease. I started looking real close (because I couldn't get the seat out because I couldn't get to the front bolts) and found a red dice in the track, I removed that and it moves like a new one now
Edit: I just talked to my son, and I was wrong, it would go backwards but not forward, and I could not get to the back bolts. he remembers this because he couldn't get it to move up far enough to drive it himself after I moved it back in position for myself, either way there was a dice in the track and when it was removed it started working fine
Old Jun 24, 2011 | 12:06 PM
Tawny's Avatar
4th Gear
Il check the tracks, I'll keep you guys up to date. Thanks!
Old Jun 27, 2011 | 01:23 PM
Project_CLean's Avatar
MMkay.
any luck? could be the switch isn't engaging either, do you hear the motor when you press it back?
Old Jul 1, 2011 | 09:04 AM
Tawny's Avatar
4th Gear
so i checked the track and nothing, everything looked good. It used to make a clicking noise and if i kept messing around with it, it would move back. now it doesn't make any noise.
Old Jul 1, 2011 | 03:49 PM
MMkay.
well ; you my friend; are running out of options,still make a noise if you go forward? if not; seems like your motor is dead,diagnosing will be a pain in the ass..jumping wires and whatnot; but you dont have much options. Check the motor, hooking it up to a constant 12v, if it doesn't work= bad motor. if it does=switch.
Old Jul 1, 2011 | 06:17 PM
Tawny's Avatar
4th Gear
It works fine when moving front, but i cant move it front because my legs wont fit in the car.
csmeance
Jan 7, 2026 06:25 PM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
