gay oil light
Old Dec 10, 2010 | 05:02 PM
f22vtec's Avatar
gay oil light
yea so I got my oil change a couple weeks ago and just a few days ago my oil light
1: stays on solid and 2: flashes as well wtf can this be? I looked in my manual and it said possibly low oil pressure but what can cause this?
Old Dec 10, 2010 | 07:38 PM
P0401's Avatar
could be oil pump going bad or clogged up screen on the pump, if its that then its not good and not an easy fix because its in the oil pan. it can do serious damage to your engine anytime you are not getting enough oil pressure to the parts so I definitely wouldn't drive it until it was fixed
Old Apr 18, 2011 | 07:52 PM
gearhead89's Avatar
6th Gear
definitely not a good sign to be driving any distance with oil light on.. get looked at asap
Old Apr 18, 2011 | 10:06 PM
cyphon21's Avatar
Check your calipers. My right rear was leaking out of a small seal around the emergency brake spring.
Old Apr 18, 2011 | 10:08 PM
FIrst, make sure you have adequate oil.
Old Apr 19, 2011 | 01:50 PM
saiko_cl_duck's Avatar
Adequate oil level, check to make sure the filter is on tight, the oil cap is on, and your drain plug is on tight.
Old Apr 19, 2011 | 04:53 PM
P0401's Avatar
What does a caliber have to do with his oil where the engine isn't getting enough oil to the sensor making the oil light come on?
Old Apr 19, 2011 | 07:21 PM
97'CL2.2's Avatar
i was wondering the same thing....how would two completely different systems be related.
Old Apr 20, 2011 | 11:31 AM
Ya know, the oil that feeds to the calipers. You haven't done that conversion yet?
Old Apr 20, 2011 | 07:48 PM
cyphon21's Avatar
damn, must of been half a sleep there... seen oil low and was thinking brake fluid haha...
sorry guys. move along, nothing to see here.
Old Apr 21, 2011 | 03:52 PM
no problem man, it happens.
I think I'm gonna use that on guys at work who don't know jack about cars
"yup, there's the oil problem, your caliper is leakin."
mada51589
Jan 9, 2025 04:40 PM
oyayjoe
Jan 1, 2019 10:17 PM
datadr
Sep 12, 2015 09:12 PM
Allen_442
Sep 8, 2015 06:01 PM
