Fuse Issues
Old Jun 1, 2015 | 08:06 PM
BArtkowsky's Avatar
Exclamation Fuse Issues
So my power window wouldn't go down the other day so I tore the switch apart again to clean it n get it working. Well i was in a hurry so in my stupidity of trying to jump the wiring without knowing which was what i blew the fuses for the power windows, i replaced the fuses with new ones and now my aftermarket radio will not turn on or do anything, my clock will not light unless you push on the clock door like you are checking the time with the car off and when you try to set the time that way as soon as you let off an re-press it it has reset itself again. Also i now have no Chirp for my alarm or panic button, yes i tried the remote button trick and that didn't work, but the alarm lights still flash when arming and disarming and hitting panic button. Also when i have the climate control set and turn the car off and back on that resets itself and doesn't retain any memory, I have checked all fuses both under the dash and under the hood and they are all good. Anyone have any idea why radio wont work, the alarm wont chirp, the clock and climate control wont retain memory? I am stumped, is there some fusible link somewhere else that powers these things? All fuses checked good....
Old Jun 1, 2015 | 08:10 PM
BArtkowsky's Avatar
car is a 97 3.0
Old Jun 2, 2015 | 09:17 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
There are 2 sets of fuses, check the ones under the hood
Old Jun 2, 2015 | 09:24 AM
i believe there's a "small lights" fuse. or check the "clock" fuse.
Old Jun 2, 2015 | 05:32 PM
BArtkowsky's Avatar
I checked Every fuse in the drivers kick panel and every fuse under the hood already, none are blown
Acura9915
Feb 24, 2020 01:27 PM
01CLOwner
Oct 9, 2015 01:07 PM
lovic87
Sep 15, 2015 06:07 PM
Soul_Deamon
Sep 7, 2015 04:25 PM
drewdeezy03
Sep 3, 2015 08:04 PM
