Engine makes a screeching noise when starting...
Old Nov 12, 2007 | 02:32 PM
Racer510dude's Avatar
Every time I start my car on a cold mourning my car would make a screeching noise for about 5-10 sec. It only happens on a cold start-up, and would screech for about 5 times and stops. Anyone know what can be wrong? I assuming that this is the starter related issue...Please help I need some input from people who had this problem before...
Old Nov 12, 2007 | 06:10 PM
TexasHonda's Avatar
My 94 Accord 2.2L sometimes screeches for 1-2 secs on cold startup. It's a loose belt. I just replaced the PS drive belt, which was against the stop and could not be tightened further. It may have loosened.
A belt screech is pretty distinctive. Are you sure it's not a belt?
If noise is not a belt, it could be a cooling fan. I've had them screech terribly, but they wouldn't stop after 10secs, unless the AC is on.
A starter that fails to release from the flywheel might cause a screeching noise. Suggest have someone start the car while you try to isolate the noise source.
good luck
Old Nov 12, 2007 | 08:47 PM
Thanks will try that...
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
