Engine Fluttering when in Park
Old Oct 28, 2011 | 08:24 AM
cjleveille's Avatar
Hey peeps, This problem I am having doesn't happen all the time, but every once in a while. When I crank the car hot/cold the RPM's drop to around 200. I have to give it some gas to keep it alive, but I can feel a hesitation in the motor when I do so. But as soon as I put it in drive, the problem is gone and it drives normal. Only seems to do it when its in Park. Like I said, it doesn't happen all the time, once every few weeks or so, Any ideas what it could be?
99 CL 3.0
Thanks Folks!
Old Oct 28, 2011 | 12:26 PM
hobo2424's Avatar
this sounds like the same problem my 98 cl 3.0 is having. you turn on it and it kills the engine. a number of things here. but im going to clean my idle air control valve and see if that fixes the problem.
anyone else chime in if you think its different.
Old Mar 14, 2014 | 06:22 AM
COLRIANG's Avatar
3rd Gear
,. When I crank the car hot the RPM's drop to around 200 then stalls, happens when I drive for 20 minutes or so and wait 30-45 minutes to start engine and it stalls and will not idle . I have to give it some gas to keep it alive, but I can feel a hesitation in the motor when I do so. After a minute or so engine runs smooth. But as soon as I put it in drive, the problem is gone and it drives normal. Only seems to do it when its in Park. I have cleaned throttle body and replaced IAC. Any ideas what it could be?
COLRIANG
Old Mar 17, 2014 | 12:25 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Tps
Old Mar 20, 2014 | 08:12 AM
AlexAcura's Avatar
happens to me aswell
if i drive the car and then leave it parked between 10-20 min then start it again.. it will do it.. any time before or any time after the car will start normal..
but between that 10-20 min the car rpm drops and often the car shuts off if i dont gas it..
black ack what is tps?? nvm throttle position sensor
Old Mar 20, 2014 | 08:15 AM
Tps
I want to learn today.
tps stands for Throttle Position Sensor?
IACV stands for?
ummm...on the H22's they have something FICTV something something...
I just like trouble shooting for my friends and would like to know the abbreviations.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
01CLOwner
Oct 9, 2015 01:07 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Billu99tl
Sep 13, 2015 11:30 AM
