electrical surges and power cutoff while driving
Old Nov 21, 2010 | 11:50 AM
jahnemann's Avatar
i was driving my car to school a few days ago and when i saw my speedometer turn off and drop to zero and then pop back to place as well as my radio, which reset itself and shot an error code at me. my car then proceeded to make a weird clicking noise and it sounded like it was coming from the fuse box or somewhere on the left side of the engine bay. my first thoughts are that the battery cables are bad and lost connection or are corroded but im jst guessing wildly. if you have a better idea im all yours.
Old Nov 25, 2010 | 10:31 PM
medium1's Avatar
I had a high pitched wine coming from the engine but I could not pin point where. One day in traffic I had no transmission in any gear. I turn the engine off and back on and got my transmission back and I no longer heard the wining noise and my amp meter read 0. The alternator was the cause of all the problems
Old Nov 30, 2010 | 09:33 PM
bobcov's Avatar
Maybe it has to do with that ignition recall that Acura had for some of the CLs? I don't know the number of that recall, but you could call Acura customer service and see if that might have had anything to do with it. Just guessing.
Old Dec 2, 2010 | 12:26 AM
hwdp420pl's Avatar
DJ MSR NRG!!
ENGINE GROUND ENGINE GROUND !!!! check all your grounds
Old Dec 16, 2010 | 03:26 PM
fliplyricist1's Avatar
Staggered 1st Gen
alternator for sure. other possible but less probable causes: grounds and/or battery terminal corrosion
Old Dec 16, 2010 | 04:02 PM
P0401's Avatar
don't think it should be the battery since you should be able to unhook your battery with it cranked and it still stay cranked and run off the alternator, so I would get the alt checked out and if it wasn't that then I would look for the ground wires and make sure they are making a good connection. If not that then I would see about the switch thing because I know they will cause a car to shut off going down the road when they go bad. This is just a few things I would check. Did you see what code it flashed at you when this happened to see what it said?
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
brandnewcolony
Sep 12, 2015 10:39 AM
HeloDown
Sep 8, 2015 06:51 PM
Aug 30, 2015 02:39 PM
