drivers side floor wet?
i was cleaning up the CL today after winters fury and noticed my drivers side floor was pretty wet. it has rained here for like 2 days straight and my car was outside so im hoping its a clogged drain tube.. where is the drain tube located so i know how to fix this?
another symptom ive noticed is it seems like my heat isnt as hot as it was before. it is warm but just not hot. im worried i may have a bad heater core but the fluid im taking out of the carpet doesnt smell like coolant. any other symptoms i could look for which would point toward heater core?
Check the grommets above the pedals. They could be leaking. Dry it all up the best you can, get under there with a light and have someone pour water all over the car and see if you can tell any leaks.
If its coolant you would know and the whole cabin would smell. My guess is you tracked in a lot of water and its just soaked there.
hope its that coolant has a very strong smell you would know or can do the tase test (don't take to much) but it very sweet. and if it windshield mine would be fine over night but the carpet leading upto the dash would also have to be wet.
UPDATE:
def not the heater core. it rained for the past 2 days and i put on 100+ miles without even touching the climate control, left it off the whole time. the carpet got soaked again however, im having some trouble finding a replacement grommet for the clutch. ill post up a pic tomm of what i got goin on down there, and maybe somone could point me in the rite direction, if not ima fill the whole area in with silicone and see what happens. so glad the dash will not have to be removed.
rockyboy
08-04-2024 10:35 AM
nanos
11-12-2015 08:41 PM
sockr1
10-01-2015 01:31 AM
