driver's door lock problems
So the problem i am having is with my driver's side door lock. I can unlock it with the key but it is hard to turn. but when i try to unlock it with the alarm i have, the little indicator inside(the one to tell if the car is unlocked or not, dunno what it's called) only moves a little bit , and doesn't unlock, then locks itself a second later. And while this happens the passenger door unlocks and then locks again with the driver's door. Any help or ideas on what would be wrong would be greatly appreciated
I would suggest faulty keyswitch mechanism in driver's door. It might also be a faulty door lock solenoid. Extensive diagnostics in shop manual for this problem. A Honda Accord manual (94-97) would work also. Check hondahookup.com for a download.
good luck
good luck
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
